Ignition system for GTti... need help!!
everblur
222
The problem is I bought the GTti engine with ECU only. So considered as engine lantai. Now engine is mounted... everything else fixed except car cannot start cos no ignition wiring. Based on your experience, what parts are required to get the car started and moving?
Correct me if I'm wrong:
- ignition coil
- igniter
- distributor
- map sensor
Anything else?
kevinkeow
116
hei... You change to GTTI already? so how are you lately? seem you having problem with it.. why get engine kosong? with ecu only? Wiring? everything not complete? well actually just to said hi. I got no experience with it. Any update about your car?
everblur
222
Hi bro, do you know anyone who can help? Maybe if they look at it they would know better... I wouldn't mind paying as long as they can help... cheers
i met a problem , do wiring tidyly with using the Voltage stabilzer or Immobilize or some like Hongkong Voltage Stabilizer with Bettery Charge or supply is better ? let me know ..the wiring will cause voltage go more stabile but do it make car performane to go distributor then to sparkplug have better effect , have feeling for turbo ? let mek now ..if yes i will go for it
