Originally posted by reddice+Mar 24 2005, 11:41 --><div class='quotetop'>QUOTE(reddice @ Mar 24 2005, 11:41 )</div><div class='quotemain'><!--QuoteBegin-vestax@Mar 24 2005, 11:15
dude , you change to a new service kit or only o ring ?. did you see them brush away the rust inside the caliper ?. once you had done it , shouldn't be a problem , unless they didn't insert in properly .
[snapback]836311[/snapback]
i see them brush away all the rust using sand paper...and the caliper is ok..i think so...maybe my bleeding is not done on proper way??can it cause the problem??
[snapback]836411[/snapback]
[/b][/quote]
if bleeding is not done properly , it won't lock up the brakes , it makes the pedal soft / spongy and there is no brake feel , but right now your not facing that problem right .
did you see them putting any high temp grease or any grease to the caliper sliders ?. cause if the slider is rusted , it won't slide smoothly and may get stuck . so ask them to check if the sliders can move around or not and ask them to put some grease .
