Originally posted by badguy+Mar 24 2005, 09:23 --><div class='quotetop'>QUOTE(badguy @ Mar 24 2005, 09:23 )</div><div class='quotemain'><!--QuoteBegin-reddice@Mar 24 2005, 08:58
update on my car brake situations
already change the o-ring on the front wheel...but,it still hot...got the piston brake out and servis it...put it back again..bleed..test about 2 kilometers...and it is hot..very hot...cant even touch the rim..
even change the rubber in the brake pump..and still not solving the problem..is it because the brake disc is too bengkok?fed-up already la..thought of buying new caliper or brake disc..any suggestions??
[snapback]835822[/snapback]
hi dude, sad to hear that!
the o-ring?? on the old caliper ??
u only services the cliper without changing it??
that's why my mechanic say have to change the caliper :huh:
only change the rubber in the brake pump when u feel and press brake like clutch!
if brake disc seldom bengkok one woh! disc will crack instead of bengkok
change the caliper lah!
[snapback]835913[/snapback]
[/b][/quote]
ya..i only change the o-ring..still the old caliper...no money la..i think the caliper is ok...because already service it and the caliper is function properly..
