How to restore Headlamps to former glory?
iman__210
781
m looking to restore my plastic headlamp...got any offering such service
iman
012-213 5886
mick87
576
112
i actually bought the headlamp restorer at giant,cost bout 15 ++,just apply on dry cloth or sponge n rub for few minutes,then wipe wif clean dry cloth,result? 60% better than before atleast
blackend
395
Johore,
so many method to clear headlamp..still curious which one is the best way..perhap,need to do DIY first..:hmmmm:
UltimateShine
66
13
www.ultimateshine.com.my
may i know what polish compound were u using ? were u using machine to polish or hand?? If machine, what would the decent machine and tools needed ??
We were using Optimum Compound and rotary machine in this video clip.
The rotary machine was "cap ayam" brand :biggrin:from China cost around RM 250, turning speed between 1,000 to 1,200 rpm.
To know more about Optimum Compound http://www.ultimateshine.com.my/webshaper/store/viewProd.asp?pkProductItem=23
Of course it can be done by hand also, all we need is a bit of patient. :top:
Vagabond
1,731
53
OK, after polishing the head-lamps with compound/plast-x/brake-fluid/cooking-oil , whatever ......
what should we apply to stop the head-lamps from dulling / turning yellow again ?
g88
3,081
54
answer : No cure. The plastic get yellowish mostly due to UV protection protection layer on the plastic has gone or possible the plastic can't withstand long time expose of heat from sunlight, bulb itself...
Even Benz one will get yellowish. The only think you can do it just keep 'maintaining' it once you restore....properly apply some wax might help slowing down the process of dulling again...
JINEIL2EN
15,317
525
Island Of Pearl
team99ers.2.forumer.com
Clear Coat especially for Clear Plastic Headlamp... can easily get in Japan Giant Automart such Yellowhat or Autobacs...
KrisMas
434
175
Do keep us up to date. I'm also very interested on the 'coating'....normal wax/sealant cant seem to last very long.
Cheers.
A friend of mine just lost his car recently..
It is a black Wira1.8 with white rims (enkei RP01)..
The Spec:-
No Registration : WEF 1969
No Chasis : PL1C99SNRSB800542
Year Make : 1995
Year Bought : 2002
Engine & Performance
-Engine Stock 4G93P
-Gear Box : F5M222 XVZF ( close ratio )
F5M222 VRXE ( std )
- Comp Box Original
- Wiring Step 1 proton
- Super Air Fuel Controller D1 Imamura
- Trottle Body Oversize ( Mivec)
- Intake Original - rebore
- Extractor Mivec
- AirFlow Sensor GSR
