can buy from hardware shop mah.... any water resistance glue which is strong enough also can la.... jz make sure u seal it up water tight or else u will see aquarium inside ur headlight....
cover wont melt so easily la... also not ask u to melt the glue till water form.... jz enough to pop out the cover can adi lor.... aiyah....
lol, is it the same side as the air filter?? if it is.... then just bore a hole
in the hibeam area for a CAI...... thats the MAIN REASON why i wanna get the glass open......
i don have heat gun,so i use this gun!haha..very easy la to open..but then i dun have any sealant to seal it back..just put it back together..as a result,no water come in..
Can anyone help me to solve my problem. My exhaust system is central box + bullet + back box if i wan to take out the central box does it effect my performance. I'm using L5 3 pistons engine. Which setup is the the best.:hmmmm:
