normally, japanese and korean car manufacturers recommend cam belt replacement at 100K. but due to our extreme hot weather compare to theirs, its advisable to take a safe precaution. change at 80k is wise. unless of coz, your car manual states differently.
example - Alfa's boxer engines require change at every 30K. delay it to 35K and voila! timing belt will snapped. thats main reason Fiat group decided to share Fiat's straight fours with Alfa. Alfa only designed new cylinder heads for it.
and yeah, it is advisable to change cam belt 1st thing when buying a used car. but we still can take risk by checking the cam belt visually. just remove the outer cover, and check the grooves.
unless of course, there is a plan for engine conversion....
