already change distributor , fuel pump , fuel filter,relay ~~~~~~~~`:confused_smile:darkemperor said:something related to ignition, electrical or fuel problem.....take to a good mech and check everything....
check engine light on?skf said:already change distributor , fuel pump , fuel filter,relay ~~~~~~~~`:confused_smile:
sometime this kind of problem makes us pening...even the mechanic also screwed-up...:confused_smile:skf said:no:sad_smile:
ya, i already send my to the workshop which can use computer checkmrbear said:change engine?
my Speedometer back side got burn, is that reason?:shades_smile:aja said:Your speedometer/rev meter working fine or not?. or any symptom of meter niddle a bit 'gila' ka?. It may be due to the speed sensor, not calibrate speedometer vs. rev meter. That y normally if u changed gears, your rpm meter straight away go down to 0 and engine black-out.
Can be due to this also.
In such case, then just get your mechanic to check.skf said:my Speedometer back side got burn, is that reason?:shades_smile:
but so difficult to find used CB6 speedometer , coz the socket different with the cb3 de
yup, aja is right...another sensitive item which sometimes people forget...especially on honda..:confused_smile:aja said:In such case, then just get your mechanic to check.
thx !:_:aja said:You in Serawak ka?. Then no komen...hard to find parts at Serawak, i guess.
Anyway, i got 1 solution to solve your problem to purchase the CB6 meter. Just call any of the these kedai potongs ..http://forum.myhavoc.net/index.php?showtopic=136. If got, later informed us here. Maybe we could help by purchase it on your behakf, pick-up those item the respective kedai potongs & courier to u. But of course payment-wise need to kawteem with the respective person who helping u la.
