When driving the car , u slow down the car speed and try reaccelerated the speed suddenly the car engine since to loss power and suddenly repower again. What is the problem? Plug,distributor ,plug cable all check still can no be solved :confused_smile: :confused_smile:
Hye Sifus,
My car F20A now got problems le. The RPM up and down like crazy until the extend that i cant drive it coz when idling mode shoot up to 2500 rpm :( Went to mechanic mentioned about manifold bocor?? I do suspect at first the idling valve. So how la? 2nd problem,engine oil leaking. Now cant control it anymore. White smoke dah keluar from the car. My ques:
1) If want to overhaul,whats the estimated cost?
2) Let say i want to swap with H22A, halfcut cost how much? Need to also change the gearbox as well?
3) H22A fuel consumption better than F20A?
Pls advise asap
Thanks
Best way is mod to H22A if u overhaul n change gear bos the cost is higest already mod it to H22A is best way .... more powerful n low fuel consumption that F20A ........!!!!Hye Sifus,
Pls advise asap
Thanks
mine is H22A (M)
Yup Yup Huhuuuuu 2gether hahahhahah !!! shok shok
stanley manual,... huhuuuu!
* FYI .. as u said F20A twincam having 150HP. is it on engine HP or on wheel HP? i dont think stock F20A twincam having 150HP on wheel.
* FYI .. stock H22A is rated from 190HP-200HP-220HP. That is on engine HP. stock ON WHEEL HP on H22A is rated from 165-175HP (on AUTO). Manual should be more.
as what u said F20A is rated at 150HP,its the HP on engine and on wheel HP is only not more than 100HP or less than that.
dont forget that there is F20B Dohc VTEC (blue top cover). its also powerful,but more people go for H22A rather than F20B.
F20A VS H22A = u said that "vtec only the differences,with the same 150HP"? i dont think so dude. if F20A is more powerful than H22A,all those guys would crazy to go n use F20A rather than using H22A dude! :mouth_closed:
F20A Spec:
Honda F20A Engine JDM
Displacement (cc): 1997
Power (bhp@rpm):150 @ 6,100 rpm
Torque (ft/lbs@rpm): 137 @ 5,000 rpm
Compression Ratio: 9.5:1
H22A spec:
2.157cc (2.2L) DOHC VTEC
10.6 Compression Ratio
H22A ver 1 2156cc DOHC VTEC, 190ps
H22A ver 2 2156cc DOHC VTEC, 200ps
H22A SpecS 2156cc DOHC VTEC, 220ps
F20B spec:
F20B SOHC 1997cc SOHC VTEC, 145ps(LEV)/148ps(4WD)/150ps
F20B DOHC-1 1997cc DOHC VTEC, 180ps
F20B DOHC-2 1997cc DOHC VTEC, 200ps
please proof to me that im wrong. waiting for ur answer :shades_smile:
