honda prelude
zaruliskandar
34
crazy4honda said:
hahah..yes its me d 1 that interupting your life last week...i already found a club..1 member of the club drive 4th gen like us..a girl..
hahahahahha... it's me which told by zul... i'm d crazy gal driving manual 4th gen lude... i repeat... manual... hehehehe.. please don't envy me.. i know a lot of you are looking for a original manual engine.. it took me few months before i found one..
well guys.. we have HPOC's forum rite now.. if you would care to have a look.. please do click on this link... http://hpocmalaysia.cjb.net/
hisha
2,016
7
YO what's up?! I'm Lam, ur manual was 5 speed or 6 speed ? cos i found 1 accord with 6 speed manual H22A ..wow~~ girl power hahaha :_:
hisha
2,016
7
mrbear said:
hisha = aiyo bro.. can u find fake/imatation Spoon Sports strut bar for prelude? off coz la its original .. =)
louis = aiyo mau kaa.. hahaha good2 one 4u laa.. off cozzzzzz.. u tak jadi beli .. i cut ur thumb!!! dun play2.. i chopshop ur ku ku bird
These has been discontinued frrom Spoon and they are rare and they are on specials now ! $399CAD approx. $334USD shipped per set within the continental US & Canada.
Mr. BEAR u got many set ah ? really interested la ..:regular_smile:
mrbear
964
planning to get CROWER stuffs.. any comments?
im thinkin of doin port n polish n oso looking for internal parts.. my car/engine clocked more than 260k mileage.. so need 2 rebuild .. this is what i had in mind
1) Crower Intake Valves 6Pc's = RM650 (oversize/higher rpm's)
2) Crower Exhaust Valves 6Pc's = RM650 (oversize/higher rpm's)
3) Crower Retainers 16Pc's = RM6xx? 7xx 8xx? (dont remember) (oversize/higher rpm's)
4) Crower Springs 16pcs = (RM???) (high temp/higher rpm's)
4) Crower Cam Pulley - planning (dunno yet)
5) Crower Rod? - planning (dunno yet)
6) 87MM Forged Pistons? - planning (dunno yet)
mrbear
964
im looking for prelude bb1/bb4 parts oso..
4-2-1 Extractor Manifold ?? anyone?
Nissin Spoon 4pot caliper (Front 2x) .. anyone??
* our front brakes are made by Nissin.. which is made for Spoon by Nissin.. ours is 3pot or 4pot? original brakes? can someone clarify?
hisha
2,016
7
original 1 pot only ...but big piston ....spoon that 1 too expensive bro...u can try to convert the R32 front 4 pot caliper..its cheap only ...can consider ^_^ ..4-2-1 can find on the half cut shop/chop shop...
yeah ..the spoon strut bar still available ? price can nego ah ? not so much money now la ...:_:
hisha
2,016
7
wow..this will spend u alot of money ...but as u like la ..the head can do as u want la ..but the piston all that ..i got so advise ...original already high compression 10.1 i think ...if using the forged piston again scare can't the block can't tahan la ...my comment is using back the original piston n change the H23A con-rod ..then will bcome 2.3 that's enough..hehehe ..y don considere to put high cam ? if no high cam u change the adjustable cam pulley will bcome useless..^_^
mrbear
964
ya lor.. i think wanna upgrade the intake/exhaust valves + retainers.. else is stock.. hehe ok laa..
really2 looking forward 2 do port n polish.. inside very2 muddy .. dirty woo.. need top overhaul later .. that's y looking for internal parts.. do one time .. no need do this then do that.. this n that.. later pening!
forged pistons n normal pistons different ar?.. as i know h22a ori pistons are 87MM.. hmmmmm.. stockss pistons oso good ar.. + ringss..
still looking for manifold.. 4-2-1 or 4 only.. header.. hehe
SPOON still got.. u want front strut only or 1 set? (Front + back) .. but advise if u got subwoofer at the back... cannot fit wan.. coz the rear bar is inside ur bonnet.
but check ur car if u already got below sway bar (Stablizer bar below ur 4ws/exhaust/rims_ then u dun need the upper bar.. but if u want oso no problem! janji no subwoofer/other things inside ur rear bonnet..
price can nego.. no problem..
hisha
2,016
7
port n polish also very expensive outside hahaha ..cheap cheap play la..like using high cam with adjustbale cam pulley n port polish is enough ..the valve using back normal ...if really got budget just change to titanium valve n valve spring hahaha this more syok man hahaha the engine can bcome more lighter....
the forged piston is different with ori ..it can made the compression more higher ..its not mean the size different ..i recomment to change the H23A con-rod..it can help u to get 2.3 cc ..cos the piston size is same with H22A just the con-rod more longer ....then u can get more higher toque power....better take out the crank shaft to doing balancing ...can stand for more higher RPM ^_^
last time i heard my cousin said his friend got RS-R 4-2-1 header for H22A ..i don know still available or not ..i help u to ask 1st la ..
n the spoon strut bar ..1 set RM300 can ah ? cos really money not enough hahaha if can more cheaper ..lagi baik la hahaha ...i think if got subwooder still can install la ..can find other place to put the woofer box ma hahaha..actually the sway bar is for cornering use ..the strut bar still can help ur car body away from "bengkok" cos of the G-force when cornering..
louismhc
387
Ho Chi Minh
eh.....bear aku mesti beli ni. Lagi i want ur spoon cloth to put on the oil filter there one for free. Wahahahaha :_:
mrbear
964
ok ok no fight! 1st come 1st !!! .. dun care! hahah
ok ok.. this is how it looks .. SPOON Strut Bar Front + Rear (1 SET)
FRONT =
REAR =
Behind View =
Spoon COMBO =
FREE FOC FREE GIFT!
all for RM 350 ..
louismhc
387
Ho Chi Minh
I'm free chopstick if you needed.....and i will use marker pen to write SPOON on it if you requested too. Hahahaha.... :X-:
AcuraV
254
Jb
i tot ori compresion is 10.6.
i agree with what you said about changing of piston, the block cant tahan unless strengthen it. (i think quite common in taiwan) re-do conrod or change of conrod need to do full balance of block.
why not change h23a block. most are same except the stroke higher than h22a.
even high high cam, alot of thing to strengthen also......otherwise cant tahan also.
haha i am collecting my car tonight (engine fully rebuilt and transplanted)...got to drive slow for sometime for run in... next plan......no money no talk:Not_Impressed:
hisha what kind of oil do you suggest for fully rebuilt engine? how about overhauled engine? i am thinking to use 10/40 castrol magnetic, what do u suggest? this oil can only use for run in period, will change it once it reach 2000km
zaruliskandar
34
crazy4honda said:
crazy bertudung girl..haha..what happen to the CF air filter???
still got... still searching for extension.. haven't go to exhaust shop yet... budget lariiii maaaa... :(
The Marketplace Top Posts
Yes people, the new VW Vento is now here in Malaysia. With a new motto that reads, "The sedan that does not compromise" The New Vento Highline is said to be the only turbocharged entry in its class so that's pretty interesting, this could just give the compact sedan an extra edge over fierce competition from Asian competitors. Read as our journalist Azmi Hasan brings you the freshest right from the launch this morning.
Locally-assembled by Volkswagen's partner, DRB-Hicom, the 2016 Vento...
