Help! Satria wheel problem
KhalilK
25
Subang Jaya
My wheel is not centered in the wheel arch. Anyone know what is causing this problem ? i've been to so many different workshops and they keep telling me something different.
has any of you guys faced this problem before ? im pretty much a noob in all this car chassis and alignment stuff.
need to sort this problem out asap as im sending my car for respray soon.
thank you thank you thank you !
KhalilK
25
Subang Jaya
as far as i know, caster cant be adjusted for proton cars right ?
does that mean i'll to look for new lower arms ? or chassis problem ?
ravingill
794
15
www.facebook.com
well bro, use ur fingers and measure the other side tire and this side tire , spacing same or not , if one side is more behind , its ur lower arm , i had this porb b4 when i bought a 2nd hand car, the previous owner whack a divider so lower arm bengkok , not costly to fix, go to body shop that repair accident cars they can check 4 u. My car last time cost me less then rm120
KhalilK
25
Subang Jaya
yo thanks for the info.
the gap between the tire and the bumper is 3 fingers. the gap between the tire and the fender near the door is about 1 finger. the distance used to be different on both sides, but after changing both my front arms and crossmember, both sides are the same, 3 in front and 1 behind.
anyways, i guess i'll go check with the ketuk mudguard people tommorrow and see what they say.
PocketRocket
'(00) Mod'er
11,388
953
Up Yours
hmm, there's a forummer called 'arrowhead' having the same issue...but with a non-accident 1st owner of a satria SE. dont know how he managed this but lets see if he can reply here to help you...
KhalilK
25
Subang Jaya
update: sent my car to different workshop to have them check on the problem today and they suspect that the previous workshop may have replaced my satria subframe with one from a satria SE which is designed that way. they also found that my absorber mountings were cracked to pieces which added to the problem.
i got the mountings replaced and the car now looks a little bit better. it still looks off center abit which annoys me to no end though so i may change to evo3 lower arms which i heard a little pushed forward by 10mm. i still want to send it for an chassis alignment check though.
i actually traded in this car in perfect condition when i bought a new car a few years ago but to cut a long story short, 20k and 5 yrs later its back in my hands in this crappy condition. i figure i'll just fix it back up and mod it a little bit here and there whenever i have the money.
anyway, can anyone recommend me a place that can check chassis alignment in the subang/sunway area ? i wont mind pj / puchong or shah alam if its cheaper there.
thanks yall
ravingill
794
15
www.facebook.com
ok bro , sunway area i got my friend.
Go to sunway college area all the car shops there , near the foodcourt / hawker food place along the same row there will be 2 tire shops i think one of them is bridgestone , in between the 2 tire shops there is one ketuk / body shop , go and look for Ah Waa , he is very friendly and does the job well. Its a corner shop exactly in between the two tire shops same row as the food court.
LuKa
618
19
Kedah
if u wanna change to evo arms might as well go for evo shocks as well where the arb is mounted on the strut body... then u get better handling
LuKa
618
19
Kedah
thats what i meant... the Evo3 Suspention is different u'll hv the ARB mounted to the Strut Body... in which if u opt for evos arm might as well hv all evo handling minus the AWD...
KhalilK
25
Subang Jaya
hi luka.
i get what you mean. i though shocks = absorbers. :P. anyway do you know if i change to evo3 lower arms together with the subframe and arb, would i be able to re-use my original satria steering rack ?
Unveiling the limited edition Opel Corsa OPC Nürburgring edition. Stunning design, innovative technology, unmatched dynamism, pure emotion and passion. These are the qualities that the models of Opel OPC features. There is a planned production of 500 units. The Corsa OPC Nürburgring has a OPC 1.6 Turbo engine capable of 141 kW/192 hp. Visual highlights are two new exterior colors, redesigned 8x18-inch...
