.: Exhaust Modification Corner :.
Jan 3, 2010
kuching
Hi, need advice from sifus.
Driving 1.3blm, manual.
Just change my header, 4-2-1 type, midbox and muffler still stock.
Which one is the recommended setup?
1. change midbox and muffler and add bullet.
2. replace midbox with bullet, and change muffler.
sb3
1,141
14
5,138
Why do i get the feeling that leaving the rear muffler stock will always give you the umphh for town use and short sprint especially for auto N/A vehicle? Correct me if I'm wrong..
aidilaidilaidil
54
becoz stock muffler is s-flow. so there are more backpressure compare to a straight flow muffler. good backpressure give you good pickup.
sb3
1,141
14
5,138
But its quite different from what the exhaust expert says that backpressure is no good at all..
I am getting bit confused here. Anybody can enlighten me on this ?
Thanks.
peterj
1,321
258
1,683
Kuching
hii all.. i m newbie here...... i have question about piping for my mivec.... since my mivec is turbocharged....... i hav do the piping 2.5' direct + hks drager muffler..will it consume more fuel (because heard from fren piping effect fc), and will it be very loud like gangster or ah beng car?
damone
500
5
Backpressure is not something you want. What you want is smaller pipes for higher velocity of the exhaust gas.
The notion of backpressure is good is wrong, as it is the gas velocity that plays a part in scavenging the exhaust gas pulses out.
Usually smaller diameter pipes will have higher velocity.
contreasjun27
9,000 RPM
9,045
25
subang
proper setup wont really affect your fuel consumption bro
aidilaidilaidil
54
No issue. If all remained stock and just change rear muffler to what you've mentioned, power wise, you get better power at higher end especially you go for full pedal, but that depends on your cat con also. If cat con clog, you get bad FC. Pick up wise, you will feel it decreases. Workmanship wise, no issue on that but i need to know the size of the muffler. Worried the body too big.
Went to one of kweng's branch at puchong last week to install my exhaust. the workmanship is excellent. highly recommended. TQ.
peterj
1,321
258
1,683
Kuching
tq.... actually i plain to do piping 2" only.. any comment? heard from ppl turbo car cant do too small piping... air might stuck at engine and coz engine no power... 1 shitting mech told me at least 2.5"
peterj
1,321
258
1,683
Kuching
and also... turbocar can put in mid muffler? any effect? plan to reduce sound if too loud
3zz
118
45
im trying finding a muffler from halfcut shop
normally how we determine the muffler still good??
i know we should see whter the size ngam wif piping or not,then have dent or x.
but how to know whether the fibre or sum say carbon inside the muffler still good?
my current muffler the fibre finish i think cos after 3000rpm the sound like tin ksng.XD
Nally
18
1,503
hi bro, I'm using 4g63t with an automatic transmission.what type of exhaust u suggest?
Nally
18
1,503
hi bro kweng, I'm using 4g63t with an automatic transmission.any suggestion what type of exhaust should i use to increase speed?
Hi All,
shopping around for a car - three top choices are Accord Euro R, Integra R, or the GTI
Anyone can share some info on the following on the GTI:
- any major differences between 05-07 models? Are all Mk5 and about the same?
- always been wary of Euro car electronics - any issues here like ECU problems, etc?
- seen a couple of 2 door versions being advertised - is the engine etc the same as the 4 door?
- what main things to look out for when checking one out?
Got plenty of...
