Engine transplant for 06 Mark X
slonez
19
Hi,
Just checking if anyone has done/lobang for transplant 3l or 3.5l into the Mark X?
If not convenient to post openly, pls PM me.
Thanks!
Ellipse506
164
5
In actuality, it isn't too difficult to do that legally. My best suggestion is to find a reliable builder to build and transplant a 2JZ as it has been proven to be the most reliable in the Mark X. If in doubt, please search the inter webs for the Kunnyz full Mark X build details and you'll see for yourself. Hope you find this useful.
6UE5t
6,000 RPM
6,756
1,300
Wouldn't it be easier to engine swap to the 3.0ltr Mark X engine instead, or the supercharged version?
Ellipse506
164
5
Then i'll pose a quick pondering point. Do you want an engine thats EXTREMELY hard to find and wont have Replacement or modification parts for, or something that is easier to work with and have many parts readily available? The 2JZ IMHO, has alot more potential for power with a very very decent twin turbo system and is much easier to work with. The v6 platform on the mark x is a much more difficult engine to work with. My opinion is based on the fact that i do all of my own basic servicing and parts replacement. For example, changing your spark plugs on the standard 4GR-FSE makes changing plugs on the subaru boxer engines look like a walk in the park.
6UE5t
6,000 RPM
6,756
1,300
Yeah very true, the Supra engine has potential to give a lot more power, a lot more parts/options available, and should be easier to maintain.
budakkampungaje
317
38
Dengkil
Toyota Supra Grade RZ
Displacement, cc 2997
Engine model 2JZ-GTE
Max.power (Net),
kw(PS)/rpm 280 ps (205.94 kw) / 5600 rpm
Max.torque(Net),
N*m(kg*m)/rpm: 46.0 kg*m (451.11 N*m) / 3600 rpm
Power density: 5.39
Engine type Serial:6 cylinder DOHC24 valve IC twin turbo
Engine information: VVT-i two-way twin turbo
Fuel system : EFI (electronic fuel injection)
Turbocharger: Twin Turbo with intercooler
Fuel type: Unleaded premium gasoline
LEV system (Low emission vehicle): No
Compression ratio: 8.5
Bore, mm: 86
Stroke, mm: 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km: 11.1
Toyota Mark II
Displacement, cc 2491
Engine model 1JZ-GTE
Max.power (Net), kw(PS)/rpm : 280 ps (205.94 kw) / 6200 rpm
Max.torque(Net), N*m(kg*m)/rpm: 38.5 kg*m (377.56 N*m) / 2400 rpm
Power density: 5.43
Engine type : Water cooling serial 6 cylinder DOHC24 valve turbo
Engine information: VVT-i vertical position
Fuel system : EFI (electronic fuel injection) (Ci (central injection)
Turbocharger: Turbo
Compression ratio : 9
Bore, mm: 86
Stroke, mm: 71.5
Final gear ratio
Fuel consumption at 10-15 modes, l/100km: 10.2
RR 005
28
hi guys
did anyone managed to do the 1jz conversion to mark x?
any comments on that?
thanks
The Marketplace Top Posts
Hi to all zth members.. do anyone know how to diy led tail lamp.. can do huh??? im usin kelisa.. Or is there any shop can do it..??:confused:
