emanage tuning and installation
vteckiller
Supporting Merchants
1,606
34
Sifu..
What good item to install
& manage evo 1 engine..
Bump: SIFU..
WHAT GOOD ITEM TO INSTALL
& MANAGE EVO 1 ENGINE..
emanage blue...
with ignition harness...
and dyno tune...
total cost RM1550...
and would be recomended if u use walbro fuel pump as well and fuel ragulator and a boost controller...
then if your engine got metal gasket even better :)
PAHAM
195
thanks sifu vtec killer.
and one more question can arr if i install
first stage *walbro fuel pump *fuel regulator * boost controller
*metal gasket
and last stage is e-manage blue + ignition harness
Bump: thanks sifu vtec killer.
*metal gasket
vteckiller
1,606
34
*metal gasket
*metal gasket
can la bro no probs...
follow your budget la...so do stage1 first then stage 2 also can no probs la bro ;)
MyToyToyota
18
How about toyota engine 4afe. What the mode i must done to sincronize with e manage.
Bump: How about toyota engine 4afe. What the mode i must done to sincronize with e manage.
cfphoon
1,857
6
kuala lumpur
vteckiller,any suggestion on mods for my 96 spec b18cr?currently i'm running on iridium plugs,twister air intake,4-1 extractor,2.5 inch piping,sard fuel regulator and ultra plug cable..i oso planning to tune my engine coz i still havent feel the right power output from my engine la after do all those mods i mention..thought of goin to ur place to install e-manage..hehe
De'WhiteCrusader
31
greets mr.joshua..:biggrin:
i'm from ipoh..recently my daily driven kelisa auto trans already installed an e-manage blue..
juz wondering if u could tune my car with the power feel...but still manage 2 save fuel at the same time??:hmmmm:
thanks bro..
cheers:cheers:
Bump: greets mr.joshua..:biggrin:
thanks bro..
cheers:cheers:
Bump: owh yes...forget 2 mention to u dat the ignition harness also installed...
:biggrin:
:biggrin:
vteckiller
1,606
34
thanks bro..
cheers:cheers:
thanks bro..
cheers:cheers:
:biggrin:
:biggrin:
hi no probs i can tune the emanage for u..
and for sure it will be tune to max power and yet to perfect lean afr for the crusing and low throttles and at full throttle will be tune for max power and right 13afr which will make best power for your kelisa N/A.
cheers...no probsss :)
G221
Over 10,000 RPM!
13,344
61
Bro, wanna ask..
How much will u charge for E-Manage, wiring, harness etc + installation + dyno on Altezza 5AT? and how long will it takes?
My engine is stock standard with only HKS intake (mushroom) & Cusco oil catch tank...guess have nothing to do or will affect the e-manage installation.
Is dyno tuning a must? or not necessary...and if possible to save some cost, do u sell a used E-Manage?
will the installation of E-Manage helps in increasing some hp, reducing fuel consumption, etc? or do you have any other solutions to install other things 1st before installing the e-manage?
how about V-Manage? Can it only set the VVTi or does is has more functions? price including installation , etc?
pm me for all the infos...can't pm u..your inbox is full.
Thanks
Bump: Bro, wanna ask..
Thanks
broz114
267
bro vteckiller, have you ever do for caldina gt4? if yes is it using blue or ultimate? how much the cost with installation + harness + dyno?
thanks,
Bump: bro vteckiller, have you ever do for caldina gt4? if yes is it using blue or ultimate? how much the cost with installation + harness + dyno?
thanks,
De'WhiteCrusader
31
thanks 4 the feedback bro joshua..hehe.:adore:
vteckiller
1,606
34
Bro, wanna ask..
Thanks
Thanks
for altezza can..
instalation charges slightly higher coz have to add 2relays and do bit more work..
would cost u full package for the blue emanage+ install +ignition harness+dyno tune...RM1650
Bump:
thanks,
thanks,
yah done before no probs..can be done...
but it cozt RM1550 but need to rent other people dyno coz my dyno is 2wd so additional RM150 so total cozt would be RM1700..all in all...
emanage blue+dyno tune..+ ignition harness+install+tune..
cfphoon
1,857
6
kuala lumpur
dear bro joshua,any suggestion on mods for my 96 spec b18cr?currently i'm running on iridium plugs,twister air intake,4-1 extractor,2.5 inch piping,sard fuel regulator and ultra plug cable..i oso planning to tune my engine coz i still havent feel the right power output from my engine la after do all those mods i mention..thought of goin to ur place to install e-manage..if retune afr ,is it included in the emanage installation package?
vteckiller
1,606
34
your mods seem good enuff for a start..u r rite..what u need rite now is a simple ecu,or a piggybag ecu..afc or emanage..emanage more worth the money coz a bit more but get ignition control as well...
ya the package is RM1550 plus install and dyno tune+ ignition harness..will also help u set your distributor to the right static timing location and also set your fuel reg and whatever necesary to make sure the cars make most optimal power and safety margins..:)
Bump:
most welcome..de'whitecrusader..
The Marketplace Top Posts
There's a new landmark up north. Finished in signature silver, the 3rd and latest Porsche Centre Penang was officially launched by Sime Darby Auto Performance (SDAP) today. The cutting edge facility will be a significant addition to Porsche's presence in Malaysia.
<blockquote class="instagram-media" data-instgrm-captioned data-instgrm-version="7" style=" background:#FFF; border:0...
