EK Extractor
pc_teh
93
1,508
Dear Sifuss,
I am driving an ek, auto tranny 1.6 vtec. Recently I changed my extractor(after market) and now
my engine is acting very weirdly.
My fren told me the becos the extractor size might affected the air flow of the engine and require tuning. He mentioned about VAFC.
I am a bit reluctant to go for that as wana keep my car stock. My question here is, if I change the
extractor back to original will it solve the problem?
Thanks .....
spoon civic
403
36
528
terengganu
Dear Sifuss,
Thanks .....
in my opinion,if u tning your car by using vafc ..your problem will solved,but the simple way is u change to the std extractor..your problem will settle if the cause for the weird engine is from the extractor....
pc_teh
93
1,508
Weird in my case
1. During cold engine driving half way while I still have my right foot on the throttle the rpm drop and the car lose power.
Can feel the airflow from the exhaust sound that it is not fluent.
2. Unstable idling. Causing the engine extra vibration.
3. High Fuel consumption
jeffayn
621
62
3,028
Klang
It pretty common that after any changes in the intake, ignition or exhaust system, you will experience "different"
Because when you do the modification you are expecting changes either to balance the car or to increase power or to .....
If your car is the old junkie, you can always calibrate the car manually...
if the mid modern car.. you can always add on...
if your car is the ultra new modern car .... you got to piggy back or get a new brain for your car..
that is because the more complicated car you got, the ecu control more , when your ecu control your car more... you control less... :rofl:
you played your header part.. so did you play your 'intake' part as well to balance it ?
The Marketplace Top Posts
Damn..
yesterday, my car got broken into and my cd/mp3 player got stolen..
damn angry! the stupdi thief break my front-left pessenger side windows
and then use the damn screw driver to korek the player..
damn ... now beside losing the player.. have to replace the dashboard area
also.. )(&^*&$^@
http://us.f1.yahoofs.com/users/6e540d58/dcd0/__sr_/3084.jpg?phY0AdDB3gtH3BR5...
