ECU Problem...Continue to read...
ogip
7
Phillipines
Welcome... Keep me updated okay...
E-tech,
I had a hardtime desoldering the IC-TA8903.
I replaced it and now the ecu is functioning and running great.
Another ECU saved and thank you very much for the great help.
E-Tech
1,115
256
3,183
Johor
Welcome bro Ogip.
Send me some "balut".. :-)
next time just bend it left and right until it breaks off
then only desolder pin by pin. Easy.
tks84
128
bring up post form diy....
just want to know what CEL code is this?happen after repair gear box and fix oil and atf cooler...
20 Electrical load detector
E-Tech
1,115
256
3,183
Johor
Sure or not???
Eld will not cause check lite to appear.
Only when you check for error code then only
you will know or c it.
Should not cause any problems.
If transplant engine with full wiring and fuse box
then will not happen tis problem...
Anyway hv you tried the bypass method?
tks84
128
fixed already....its the wire from the positive terminal not tighten enough....
then came out another signal...
cel code 15..
Ignition Output Signal missing or defective ignition output signal
stand in front of engine for half an hour couldnt find anything...
tried bypass still come back...but idling,start and drive no problem..
nia ma....go repair car then only problem come out....
---------- Post added at 06:33 PM ---------- 6 hour anti-bump limit - Previous post was at 01:05 PM ----------
check on the net...its it possible could be the starter ( as starter is the ignition)
cause its situated on top of the gearbox..
last week i change the O ring in the gearbox...so the mec maybe forgot something...
whats sifu comment?:idea:
tks84
128
sorry wrongly diagnose...actually its the ignition coil...my car don't have that just the distributor (i guess)
is there any chance to repair? like change the carbon inside/service?
E-Tech
1,115
256
3,183
Johor
You need to change dist.
To repair go get a b20 crv's dist and take
the ignition module and replace it to ur original
dist. Thatcshouls fix ur cel15
tks84
128
which is better?repair or replace? if i go to chop shop and get a recond wan better?
if a new set expensive arr?
cannot service?
can tahan for this month the disc? i pokai already repair a lot liow
Following the fact that Jenson Button has just taken delivery of one of twenty biblically-powered Mercedes-Benz DR 520’s, and considering that he took the estate version , it’s now officially cool to be seen in a wagon.
Just in case you were wondering, which you probably were, the 520 in the name does indeed stand for...
