Dyno result sr20ve, 2.0L na
6UE5t
6,000 RPM
6,756
1,300
actually there's damn a lot of things you can do to improve fc.
1. Reduce overall engine load like what Gunnerz suggested. Aircon compressor kick. Check that your grounding is all good. etc.
2. Lighten your car interior, remove heavy-ass subwoofers and spare tyres (replace with patch kit) and skip all the downforce mods.
3. Fuel filter, ignition, fueling, air-intake - all these need to be in optimum condition.
4. Spark - some say that bigger spark will help. I personally don't really know. Kits like those that increase spark help make things run smoother. Back then with my wira I tested and share in ZTH this spark plug cable that increased the spark and that seemed to work wonders with my power which indirectly helped my FC.
5. Put a brick behind the accel pedal. Driving smoothly and non aggressively improves FC and keep revs below 3k rpm. You want FC you gotta live with the boring.
Use lightweight rims.
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
Your blm is quite good. I always heard of horror stories regarding the blm auto
I've edited my post as there is typo there which might confused u.
My BLM is auto and it can go above 300km with RM50. Anything below 280km indicate something wrong if i drive as usual. So far i have never been able to reach 14km/l on it. Considering its a basic plain engine, thats a not to bad figure. My waja with single VVT is 14km/l anyday.
brokenjars
229
16
Kedah
My friend had a blm before. Can hardly achieve your fc in penang traffic. His fc only average around 11km/L when new! And my another friend said his waja auto currently is at 8km/L.
I carry my tool box, parts, bulbs, extra water bottle, etc, etc in my boot........lol
brokenjars
229
16
Kedah
ehh u from penang ?
Yup I'm a penang lang, so to speak.
Btw my car current has a squeaky clutch pedal. Applying white lithium grease at the push rod at the clutch pedal only helps a tiny bit. Any reliable mechanic to recommend in Penang?
brokenjars
229
16
Kedah
Same, I carry all my tools too. A full toolbox with allen key set, screw drivers, bots and nuts, electrical tester, tapes, wrenches etc. I also carry a full set of spanners, complete tools to change tires, big scissor jack, air pump, spark plug remover tool, spark plug puller, tire gauge etc. lol
  • Like
Reactions: vr2turbo
So I am not alone......hahhahaha
Sometimes can be the spring, and worse case the internal part, meaning the rubber seal rubbing against the sidewall. The squeak sounds when press or release or both action?
brokenjars
229
16
Kedah
Exactly same with honda s200 clutch sound if u see at youtube. Both press and release got sound. Both clutch pump already changed new also have sound
sweelt
Nov 6, 2016
2,306
248
663
Penang
Squeaky is ok as long can shift gears.
Last time mine intermittent stuck and wont bite. Then suddenly bite. Check found out bearing kaput.
So i now on oem clutch, "daily" drive in penang is not for puck puck clutch. Hahaha....
Yup I'm penang lang too. Hi...
brokenjars
229
16
Kedah
Haha the sound is driving me crazy.. imagine the daily traffic and the frequent squeaks in need to hear... Nyekkk nyekk nyekkk nyekkk~ omg going crazy. I have to fix the sound before i go crazy lol.
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
Thats not called 'carry my tools around' but 'carry my workshop around'.
The Baja 1000 is one of the most grueling, demanding and torturous rally’s in the world. And Bill Caswell is going to take part in it with his $500 BMW E30 bought off Craigslist and put together in his mom’s garage and partially at the SEMA show before heading to the sand dunes of Mexico.
Caswell’s no stranger to competing in beat up machines and...
