Dyno result sr20ve, 2.0L na
actually there's damn a lot of things you can do to improve fc.
1. Reduce overall engine load like what Gunnerz suggested. Aircon compressor kick. Check that your grounding is all good. etc.
2. Lighten your car interior, remove heavy-ass subwoofers and spare tyres (replace with patch kit) and skip all the downforce mods.
3. Fuel filter, ignition, fueling, air-intake - all these need to be in optimum condition.
4. Spark - some say that bigger spark will help. I personally don't really know. Kits like those that increase spark help make things run smoother. Back then with my wira I tested and share in ZTH this spark plug cable that increased the spark and that seemed to work wonders with my power which indirectly helped my FC.
5. Put a brick behind the accel pedal. Driving smoothly and non aggressively improves FC and keep revs below 3k rpm. You want FC you gotta live with the boring.
Use lightweight rims.
Your blm is quite good. I always heard of horror stories regarding the blm auto
I've edited my post as there is typo there which might confused u.
My BLM is auto and it can go above 300km with RM50. Anything below 280km indicate something wrong if i drive as usual. So far i have never been able to reach 14km/l on it. Considering its a basic plain engine, thats a not to bad figure. My waja with single VVT is 14km/l anyday.
brokenjars
229
16
Kedah
My friend had a blm before. Can hardly achieve your fc in penang traffic. His fc only average around 11km/L when new! And my another friend said his waja auto currently is at 8km/L.
I carry my tool box, parts, bulbs, extra water bottle, etc, etc in my boot........lol
brokenjars
229
16
Kedah
ehh u from penang ?
Yup I'm a penang lang, so to speak.
Btw my car current has a squeaky clutch pedal. Applying white lithium grease at the push rod at the clutch pedal only helps a tiny bit. Any reliable mechanic to recommend in Penang?
brokenjars
229
16
Kedah
Same, I carry all my tools too. A full toolbox with allen key set, screw drivers, bots and nuts, electrical tester, tapes, wrenches etc. I also carry a full set of spanners, complete tools to change tires, big scissor jack, air pump, spark plug remover tool, spark plug puller, tire gauge etc. lol
Reactions: vr2turbo
So I am not alone......hahhahaha
Sometimes can be the spring, and worse case the internal part, meaning the rubber seal rubbing against the sidewall. The squeak sounds when press or release or both action?
brokenjars
229
16
Kedah
Exactly same with honda s200 clutch sound if u see at youtube. Both press and release got sound. Both clutch pump already changed new also have sound
sweelt
Nov 6, 2016
2,306
248
Squeaky is ok as long can shift gears.
Last time mine intermittent stuck and wont bite. Then suddenly bite. Check found out bearing kaput.
So i now on oem clutch, "daily" drive in penang is not for puck puck clutch. Hahaha....
Yup I'm penang lang too. Hi...
brokenjars
229
16
Kedah
Haha the sound is driving me crazy.. imagine the daily traffic and the frequent squeaks in need to hear... Nyekkk nyekk nyekkk nyekkk~ omg going crazy. I have to fix the sound before i go crazy lol.
Thats not called 'carry my tools around' but 'carry my workshop around'.
Shelby Supercars (SSC), manufacturer of the ultra high-performance Ultimate Aero Twin Turbo, set the new "World’s Fastest Production Car" record earlier today with an average top speed of 255.83 mph. Confident of the 1183 hp vehicle’s abilities, SSC set out to validate their top speed claim in accordance with the strict guidelines set by Guinness World Records. Among other requirements, in order to meet Guinness’ approval, a...
