hi guys,
actually yesterday my hands were a bit itchy, went to my car, using a philips screwdriver, take out the whole digital air cond module, then take it back to my room slowly research, i managed to disassemble the front part (the bezel), only four screws at the rear, then using a flat screwdriver to slowly remove the hook n pull it out, i saw two bulbs with blue coloured condoms, these condoms r similar to our wira cluster meter's condoms where they turn the yellow coloured bulbs to white light, took out the blown bulb and went to some electronics shop n finally got it, although it's not of exactly the same model/spec, or rather i should say size, it doesn't matter so long as it's a 12v, guys please do not go to normal accessories shop, even a shop as big as brothers doesn't have it, looks like this type of bulb is really hard to find..... then just now fixed it up already, n it looks great!! and everything is back to normal except i gotta buy another bulb tomorrow as the light on both sides r not well balanced, the new bulb is brighter but the old bulb isn't..... n remember guys, actually you do not need to remove the whole bezel, it's not required, once u take out the whole module see behind there u can c two holes one at each side of the socket slots, use a flat screw driver or a philips to turn counterclockwise, then voila you manage to take out the holder with the bulb, remove the blown bulb, replace the new one, n remember to follow exactly the way u take the bulb out, u gotta slot the two holes of the bulb connector thru two mini holes of the holder, then guide the bulb connectors thru the lines made ready at the holder, fold a few rounds at the edge if u wan, once done for both sides, voila, remember before u put it back, use watever u wan, i jus use a flat screwdriver to scratch the contact surface to the bulb holder, u''ll c two identical semi-spherical bronze surface, that's the contact point, otherwise it's a bit sensitive, my first attempt failed coz of the loosen contact or i would say intermittent connection, remember put it back the way u took it out.... mine's a gsr dashboard, so only two screws to take the whole central dash out, but for wira, there would b few more additional steps.....
