Rleo6965
@dawnryder
Just want to know if the information I gave you have solved your problem. Hope it did.
yes it help a bit. done my problem with that 3 wires. I've connect it directly to similar wires i found from bundles of wires from the computer box. and now, no more exposed wire. But the engine is still have the same symptoms.@dawnryder
Ada. Twin Dellorto Carbs DRLA - Alfa Romeo 33 here :-)Nobody play with carbs anymore? Helloooo????
I've settled the problem already.. Its the idle limiter that need to be adjusted. Once adjusted, my engine is ok already.I think you need to send your ECM for diagnostic test. To confirm if it's ECM working. They must also check if sensors and TPS working normally. They also must confirm wiring connection of O2 sensors, Coolant Sensor, Fuel solenoid drivers was correct. Specially the 3 wire TPS or Throttle Position Sensor. It must be wired w/ the same color or wire stripe.
You must also check the vacuum lines if properly connected.
Check color spark plug gap insulator was too white. Adjust carburator for slight richer fuel. Color of spark plug must light brown.hi sifu I bought a used beat up lmss which got some problems that I hope sifus here can advise me.
Anyone knows why my car is hard to start after running, I mean its not hard to start when cold but after running hot then stop then hard to start. I need to step full throttle then only can start and ya when stop the engine still runs about a second. Any advise is welcomed.
