do dry and wet compression test also....Does it mean I need to overhaul my car? Or are there any alternative way I could check for the problem? :hmmmm2:
if wet result all 4piston reading average similar to dry test average then should be just the valve seal...
if dry got 1 piston low compression then wet test all become average means that piston ring probably kong edy...and should do overhaul...
