D16 low and high compression pistons!Nippon racing...............Rm800!pm me now.Than
WalBro(Apexi)
543
Perak
Fits D-series Civic Engines From 88-00
Compression Differs Based On Motor Application Between 10-12:1
Avalable In Std .020 .030 And .040 Oversized
Comes With Performance Nippon Racing Chrom Rings
These Chrome Rings Are Far Superior To The Factory Honda Cast Rings
Pistons Also Come With A New Set Of Wrist Pins
Great Alternative To Expensive Forged Units
WalBro(Apexi)
543
Perak
Fits D-series Civic Engines From 88-00 D16a1 D16a6 D15b D16z6 D16y8 D16y7 Dohc Zc Sohc Zc Etc....
Compression Differs Based On Motor Application Between 8-9.5
Avalable In Std And .020 Oversized
evoX2
1,167
KCH
wonder if this piston will increase the performance of my car? For pick up or top end?? How about the FC, varies a lot from stock piston?
zamrioo2
180
mr walbro... if put in b16a... what the cr will be...? izit lighter than p30...?
WalBro(Apexi)
543
Perak
sasuke said:
If not mistaken this is the ZC piston.
d16 all motor can use tat pistons.for d-series u can use used ZC engine piston to put in ur sohc engine to increane the compression.Thanx!
blur_civic
777
KL/PJ
So is this the ZC piston?
devilz 78
376
9
kuala lumpur
Re: D16 low and high compression pistons!Nippon racing...............Rm800!pm me now.
hi! all D-series means zc dohc too?
please help me to d.i.y my ecu.....chipping the ecu or any.....anything need to add in ecu or change???:confused:
