PCT/CTR piston and compression ratio
vTec[Rock]
625
Perak
from the very limited sources i have (omniman, c-speeds compression calc, and various HT users) there seems to be a rather large difference of opinion on the effective compression ratio's of CTR pistons in blocks other than the b16b
personally the range of difference is the problem. to me .2 or .3 difference wouldnt bother me, but recently people have been talking of 1+ point differences in the compresion calcs available online today!
i really trust omnimans opinion, i have spoken to him once about a particular head he ported, and the #'s he achieves speak for themselves.
i woul like some help in getting to the bottom of this. i have a set of of overbore ctr pistons available to measure if anyone can point t me what needs to be measured.
vTec[Rock]
625
Perak
Topics copy from Honda-Tech.hope will nop angry all.
i'm really interest about compresion ratio.let talk here........Yooooooo
vTec[Rock]
625
Perak
may I know,who can help me calculate my engine compression ratio?Pm me.i will send engine spec and piston sheet pls help me calculate.thanx!
D16Y6
161
[snapback]828246[/snapback]​
hey tiong koh ask xenix lar.... last time he got make the format.. mayb not i forgot :P
basahboy
203
Angsana Hilir
sori to bother this already dead topic but nevertheless we are always engulf with compression ratios and forged pistons...
CR can be calculated based on a number of factors (u can get it in the net lah)...so no need to explain...however, it is not always necessary to have the CR in direct correlation with horsepower...
BUT the rule of thumb is that for every 1 pt increase, the relating increase in HP is only 3% AND that is mostly the rule of thumb for compression ratios for 9+ and abovelah....
so, if your current engine is having...say 170bhp with comp of 10.6...and you put in the forged pistons n bump the comp to 12.0...the hp increase will only be to about 177bhp or about 4.2%...hmmm not much considering the amount to time and money spent...
THEN AGAIN.....this is only the rule of thumb..of course many other factors can take into consideration like cams, etc....so in most likelyhood, changing pistons should not be a priority...the airflow should be the no.1 priority i.e. the intake manifold, exhaust manifold and the HEAD...all must jive because any turbulance in the flow of the air will cause the engine to loose power...
ADIOS....
Hi, anybody here encounter a problem of their alarm go off anytime for no reason? What should i do?
I installed central locking system and alarm system with shock sensor for more than half a year already. Before this nothing wrong, just this few days started to go crazy.
The car just put there nobody touch the alarm also go off. but only when put in my car porch where there is no sun, and mostly happen at night (morning also got, but not always). tired already everynight the alarm go...
