Buy & Sell your RX-7 and RX-8 here.
savahn
323
60
Why do you two want to buy an FC3S? Most of the FCs that you can find nowadays are pretty banged up and in need of massive parts replacements.
adamckc
129
19
guess they don care about the interior,, and as for engine can easily buy a half cut and swapped in.. and then wa la ready for drift.. or is my guess wrong?
savahn
323
60
An FC is not the best car for drifting. Easier to use a Nissan Silvia or Cefiro (A31). Or one of the older models like KE70s and the like.
The FC's setup is for grip and it is a grand touring type of car. If you want to race on a circuit, some adjustments to the suspension setup and it makes for a very serious race car (just not as good as an FD). But drift isn't a strong point.
adamckc
129
19
the cost has taken over the choices of car..
i think the r e blog apparently has died..
stutzedward
3,416
561
FD RX7 was the best rotary sports car. Came RX8 but performance was a serious let down. All in all, rotaries are also unreliable compared to piston engines. Maintenance cost is high and needs rebuilding very frequently if pushed hard. So...that's why RE dies...
savahn
323
60
Hi Adam,
Sorry for being such a stick in the mud. But seriously, passion is easily killed when you have to fork out time and money to fix all the problems of a 20 plus year old car that has been trashed (or neglected) by previous owners. I wish I had my own workshop.
Not everyone can afford it. Can you imagine driving your car for a few days in a month after which it has to spend the rest of the month in the shop? It is not pleasant.
I've easily spent twice the original price I paid to fix up my FC from the axle frames to replacing the transmission to rebuilding a blown engine. And it still has more work to be done to internals, body work and suspension.
If the purpose is to drift. There are better cars to drift in that are cheaper to buy and run. Even an FD is a better idea.
---------- Post added at 06:42 PM ---------- 6 hour anti-bump limit - Previous post was at 06:28 PM ----------
Rotaries are no more unreliable than pistons. If anything, they are more sensitive to maintenance - or the lack of maintenance. I.e. they are more fragile... really really fragile.
Piston engines don't need to be rebuilt - which is essentially an "overhaul" for pistons. Rotaries must be broken down at least at 100,000 KMs. Also, our weather and traffic jams are pretty crap for hot running rotaries. People do not know this and this is the primary cause of problems for rotaries.
If you compare an old cast iron piston engine to a rotary, the piston is going to win because it can overheat and seize up without too much problem - it will re-start when it cools down. Rotaries can't - they warp and melt internally.
But if you compare a modern alloy piston engine to a rotary, the difference is not too big. Alloy piston engine heads will warp and become unusable when they over-heat. And that's what a rotary is - it is an all alloy engine block - aluminium, iron-alloy, carbon/ceramics and cast iron.
There is one white non-turbo FC drop-top model in PJ area that has run nearly 30 years without issue.
adamckc
129
19
what i hate the most is,,, the car died in somewhere then waits for hours for the tow driver to come.. who need to shake off first.. ha ha..
my1keen
18
looking for RX7 FD3S for project with broken/damage engine or without engine.
must be with registration card (road legal)
PM me.
Thanks
The Marketplace Top Posts
hey guys.i would like to give a big applause to titan for what they have achieve.the suspension so far for me is very impressive.not too low,n the ride height for my car is totally the same.Although the spring is a bit hard but it's ok for me cuz i've transplant another engine and the engine need a new support from the absorber.maybe in the future i need to tune it again.overall for me it's worth every cent i've paid even though the price is a bit high.it's better than getting a cheap one n...
