BOV got engine oil
huakenny
LB Performance
9,126
240
Kota Kinabalu
ok turbo sifus here,
my probem is my bov got engine oil come out....
wat is the problem? izzit i hv to service my turbo? i clean intake hose b4....but after few days the oil coming out again...really sienz la make my whole engine bay dirty
any ideas wat wrong wit it?
car spec:
Evo 3 gsr stock 4g63 wit greedy blow off n arc intercooler
MizuChi
117
Japan
Oil coming out of BOV? That's the first time I've heard of such thing. Sounds like there's a leak somewhere, and my best guess is the turbine itself. Any funny sounds when boosting? Or funny feeling during boost? I kinda doubt it but it may very well be that the turbine is leaking its oil into the piping.
huakenny
LB Performance
9,126
240
Kota Kinabalu
so the turbine hv to service huh?
coz everytime after whack the engine...bov sure lots of oil coming out and my engine oil level wil reduce..so hv to top up..
MizuChi
117
Japan
Yes, since the turbocharger uses engine oil to lubricate the bearings, it's not unlikely your engine oil level will drop. See the image I posted for my guess of where the leak may be.
I would probably just look for another turbine..
Oh and BTW, I would refrain from driving the car if I were you.. Engine oil + Air + Fuel + Combustion = not very pleasant smelling (white?) smoke and may possibly ruin the engine..
huakenny
LB Performance
9,126
240
Kota Kinabalu
the car din smell bad n white smoke le..like normal...juz the engine oil in BOV problem..
tat turbine worth for repair/service or juz change another one?
Maxx
2,072
42
PD-Putrajaya-KL
www.zerotohundred.com
doess ur breather hose (the one connectod at the valve cover) connected back to ur airfilter?
if u whack ur engine, engine oil sometimes blow into the airfilter and then sucked by the turbin, then to the intercooler, and manifold.
check ur intercooler also, maybe got oil in there too.
acbc
4,615
KD
I got the same problem b4 I relocate the breather hoses from valve cover to oil catch tank. Had to remove all the intercooler pipes + intercooler itself for chemical cleaning. Lots of oily residue inside.
kRiminaLz
552
Docklands/SAlam
yup... this thing happened to me b4...
thought the turbine almost kong, but dont haf any white smoke... its a bit wierd heh..
but after consulting a few plp, found out that its bcoz of the breather hose.. save $$$ for the turbine..
huakenny
LB Performance
9,126
240
Kota Kinabalu
then u put the small filter at there o connect OCT?
alfian96
294
hi guys ,
just wanna share some experience too. My car also like that ler :mad:
it will flow into intercooler as well, come out from BOV , all over engine bay .. all becoz of the stupid turbine.
kuakenny , what engine ur using ? can solve it ??
if normal drive it wont happen right ?? only when turbo on... right ??
:cool: :albertein
dorifto_deMoN
62
okie, if u`re car doesn`t hav white smoke coming out from the exhaust, that is one other thing. at ur rocker cover will have an outlet pipe(usually just one but every engine got this outlet. when u`re whacking ur car(high speed driving or u just high revving) the oil will vaporize and go through this outlet. factory standards, this outlet will go back in ur throttle body(via hose). This is done to recycle back the vaporized engine oil.
so what u need to do is unplugged the whole intake system(is this the right term??) which is your intercooler hoses, your air filter, the intercooler and the bov. clean it up. make it nice and shiny.
then, the important part. the hose from the outlet pipe should not be joined back to enter the throttle body. the cheap way is just to find a longer hose, connect one end to ur outlet pipe and the other end goes down ur engine bay. meaning u just leave the hose pointing to the ground. so all the vaporized oil will go straight to the road.
the other way is to buy a oct(oil catch tank), and the hose from the outlet pipe goes in the oct. usually(maybe all) OCT has two inlets.it doesn`t matter which one is connected though.
that will hopely resolve ur probs. but if it doesn`t, maybe it has to do something with ur turbo.
evors
60
Johor, Malaysia
Turbine Problem
Bro,
I think your problem is exactly as what MizuChi explain. Your turbine might have an oil leak, meaning the oil is now getting into your intake. Check your intercooler too, might be filled with oil now (not healthy as oil is not compressible). My friends L2 had the same problem, oil spewing out of the BOV all over the engine bay even unto the windscreen. He changed the turbine, all ok now. Had to clean the whole intake system too, I/C, piping, bov, throttle body, intake plenum.
Do u need an EVO3 turbine, might consider selling mine at the right price. Upgrading soon :smile: Or, this is the right time for U to upgrade to TD06.
huakenny
LB Performance
9,126
240
Kota Kinabalu
alfian96 said:
hi guys ,
:cool: :albertein
i think so.....if drive normal is ok.....
Greetings,
I had been informed by my foremen that my EVO 3 gearbox - 4 wheel shaft bearing had already spoilt.
The cause is my previous foremen ( my friend ) had not fixed the housing for the bearing which caused it to grind with the Gear Box alloy housing and damage it. Now the bearing and the housing already makan. The housing apparently they can try to modify but the bearing needs to be replaced.
I need to find the bearings.
I had been informed that is not available at...
