Eh.. then become destrokerlah.. B16b stroke only 77.4mm (according to a friend). I think it's in the region of 80mm-85mm? lower than B18c, but higher than B16A?very pening la the question...
is it u want to stroke up the b16b to bcome b18c or wanna change the b16b block straight to b18cr block?
i think he wanna change the whole block.very pening la the question...
yes! the whole B18CR Block to B16B...i think he wanna change the whole block.
should b no problem izit?
its 77.4mmEh.. then become destrokerlah.. B16b stroke only 77.4mm (according to a friend). I think it's in the region of 80mm-85mm? lower than B18c, but higher than B16A?
But it could be 77.4mm with longer than B16A rods, since the last time in B16b.. low end torque.. aiyoh!!..
You know the actual stroke?
what actually happened to your B18CR block???? hih hih hihhhhh and dun forget to change the B16B ecu instead of swapping to B16B blockyes! the whole B18CR Block to B16B...
For what reason u wanna change ??to all honda sifus...need advise here!
what need to change if wanna to upgrade to B18Cr block?!or just simply plug n play using all B16b parts?
TQ!
