B16A fuel comsumption
myupgrade
106
if u wanna more fuel save, just install vafc or safc..usually stock engines (including japan cars) are fuel rich..if im not mistaken, japanese engines can work on lean fuel ratio..
dont be tricked by any of snake oils, gadgets or else..
aimanxkisah
158
zaki said:
KL - JB speed around 140-16km/h then go back to kl 110km/h all the way. 60litres = 800km/h. how bout that from a stock b16a?
waaaaaaaaaaaaa
using auto or manual bro?
i used vtec sohc cannot make it like ur FC.. never mind that...when balik kg i'll try it again but this time using the same engine as urs:mouth_closed:
aimanxkisah
158
hattech-v said:
what to do... have to follow u...
wonder what will happen after u add another extra cam for ur ride. haha
who's following who.. next time try again with xtra cam..:shades_smile:
zaki
328
aimanxkisah said:
waaaaaaaaaaaaa
family spec'd stock b16a manual. not my car actually.
EK9wanabe
158
my std b16a around that lor...rm10 -->65-70km with VTEC open some time...if asyik tekan cannot get la..
Kye
177
Japan
i think that fuel consumption is good because mine only can go RM50 = 260km ...
hohoho.... need a block urgently hehehe
Shoken7
193
my B18c eg is drinking fuel like water
is there any hope for it?
10bucks only 40-45km
50 bucks only 200km
i think there might be somthing wrong with my engine?
pok nik
640
7
perhaps vafc can save a little bit of fuel but almost unnoticable lah...figure this out, u want to go slow, it rconsumes like any other cars, u want to go fast, u need to use more petrol la kan...its vtec we're talking bout...vtec..vtec...compromi la a bit...i'm not refering to any technical theory cos i'm not good at it...so its common sense...u gain some, u loose some...just like when ur using a close ratio,,u gain pickup but u loose top speed a bit....
zaki
328
50 bucks only 200km
what kind of setup do you have? do you have fuel regulator? what injector capacity are u using?
Shoken7
193
i just got the car a month ago
i dont see any fuel regulator in it and not sure what injector capacity im using
you can say i am a noob
im still new and trying to learn
anyone know how to install this turbo timer?
got wiring diagram as well? i send to aksesori shop..they juz conect d turbo timer function...others function cannot works la...help
