Apexera SAFC & VAFC
hamsap
1,524
PJ/ KL
khoyos said:
well, i personally dont use gsr engine. so i might be wrong. sorry if i gave wrong info...
Nothing personal, Khoyos. Cheers :)
e819
1,261
agree wit whatdamn n hamsap says... i will get it tune by the pro's...
just asking out of quirisity(spelling error 4 sure)....
ok.. another Q.. i found the knk(knock rite?) reading at the sensor check.. 80-100
but on the main display it write knk 0x
mind explaining??
acbc
4,615
8
KD
khoyos,
I'm using e-manage blue and have this CEL problem every now and then. Found out why... darn speed sensor and injector wirings are faulty with an OBD tool. Apparently, the wires from the ECU is so sensitive that a slight touch will cause CEL to appear. Must have happen during the installation.
forsaken_avatar
50
A'PEXi AFC neo on CamPro? urgent...
i'm interested in installing afc neo on my waja campro 1.6. it's equipped with the siemens ems700 ecu... went to n1 for some enquiries, they said its possible. but i'm still sceptical on whether it can perform well in my car... would it coz any problem with the engine or anything else?
any sifus, ur help would be appreciated gr8ly! thanx!
brother
87,094
18
5,138
cheras,kl
need help for all sifu......
my safc2 LCD is burn totaly now dun have display now......got any place can repair?
alexklg
4,099
11
www.zerotohundred.com
hi, i don't think it can be done. many discussions had been going around on our ECU and its tune-ability but so far, i do not see any substantial proof whether we can tune Siemens.
forsaken_avatar
50
hmm... maybe i should change the ecu straight for betta performance... any brilliant suggestions on good ones? axt? obit?
hansonchen
71
safc 1-button vs 5-buttons
i'm planning to buy an safc 1-button or 5-buttons type to install into my 1jz and get it tuned, how good is the 1-button type compared to 5-buttons or both compared to safc 1? anyone can recommend a good tuner shop in town to tune my 1jz? my ecu's already chipped, how do they tune these type of ecu?
any suggestion and advice would be most appreciated. thanks
ecupro
323
6
zeroxseven,
You quote:
"I plan to fix LT8 to my Gen.2. Possible or not?"
Bro, first of all, LT8 not support electronic throttle body or "drive by wire".
If you really want it, you have to mod your throttle body like Proton Putra, Pron Waja (Mitsubishi type) or Mivec, then, connect cable to your foot throttle.
And, other thing is, you have to check on crank sensor ( i think on flywheel ) and cam sensor ( on engine head ). You need those input sensor to trigger the injectors and ignitors.
Good Luck
Vagabond
1,731
53
1,648
APEXi AFC Neo compatible with i-VTEC?
Guys,
I'm confused.
APEXi's web site states that AFC Neo is not compatible with i-VTEC engines, but local tuners are telling me that it is.
AFC Neo seems to be newer than the V-AFC 2, but is priced cheaper.
The thing is, I've got an i-VTEC engine, which should I put in? AFC Neo or V-AFC 2?
Thanks for the help guys.
zzainudin
503
Subang selangor
hallo ZTH sifu's...
got 1 more question..
is it installed the safc can damage some part...
i think my TB wanna be (KONG) in this time...what i was heard if u r not properly install it has to be..
i'm using 4G92 DOHC Non Mivec and the engine code doesn't has in the manual setup..so can i using the mivec setup...it's same ECU for mivec n non mivec ..
1st day i installed it my engine can't start...(RPM drop until engine died) so my tuner adjust the timing @ TB n then it's ok..
Just Wonder..dont know if my TB really kong coz it's from h/cut..
Lastly for u all info after install the safc my fuel compsumsion it's very2 ok...0.12 Cents = 1km
thanks..
m1adam
258
be carefull if ur fuel mixture 2 lean boom engine,i tink ur afs ny tuned properly coz ur symtom happens when its hot in da afternoon i tink ur afs not reading the air temperature properly causing the ecu to nt calculate the air density properly causing wrong air to fuel ration and thus making ur knock sensor go haywire.
my air cond is working fine til just now the air cond pump just cut off and would not turn on....i suspect ither the pump switch or the fuse or relay is blown.. but i don know is there a fuse or relay for the air cond pump?? pls help!!!
