If your VR is there, they might probably be scared of your car. SifuOver driver's ability leh!.....
vr2 as in my ID, means 2WD only, how to tackle them.....hahahahhahaIf your VR is there, they might probably be scared of your car. Sifu
The Satria is probably 2WD also. Unless the owner go crazy and equipped it with an illegal full time 4WD transmission.vr2 as in my ID, means 2WD only, how to tackle them.....hahahahhaha
Probably they give face because VR is EVO great great great great great grand father......
Probably highly tuned with very rich mixture to get that......The Satria is probably 2WD also. Unless the owner go crazy and equipped it with an illegal full time 4WD transmission.
Haha, VR = Evo 0 while theirs are Evo 9. Far gap indeed. BTW, will your VR spit flames from the exhaust like some of the Evo in that video? This is probably due to too much heat in the engine after such a heavy pushing on the engine?
That might not be too good for this engine I guess. Especially for his exhaust manifold...Probably highly tuned with very rich mixture to get that......
Turbo running fast needs a richer fuel feed. Too lean can overheat or burn the engine....That might not be too good for this engine I guess. Especially for his exhaust manifold...
Richer fuel feed means injecting more fuel from injector which equals to increase the fuel consumption as well?Turbo running fast needs a richer fuel feed. Too lean can overheat or burn the engine....
Drive turbo think of FC then might as well don't drive.....hahahahahahaaRicher fuel feed means injecting more fuel from injector which equals to increase the fuel consumption as well?
Then, for cars like those new german cars that uses turbo engine and they claim it can reduce fuel consumption due to the reduction of displacement, how did they do it? Or is it because those cars are running on low boost?Drive turbo think of FC then might as well don't drive.....hahahahahahaa
A 2.0L engine when boost up can be like 3.0L power so the consumption is like 3.0 not 2.0.....
They are comparing say 1.4 turbo to a 2.0L NA. The 1.4 of course will have better FC.Then, for cars like those new german cars that uses turbo engine and they claim it can reduce fuel consumption due to the reduction of displacement, how did they do it? Or is it because those cars are running on low boost?
Or is it his turbo misfiring????:hmmmm:Probably highly tuned with very rich mixture to get that......
@ maybe they came out wit mid boost for optimum power minimum effortThey are comparing say 1.4 turbo to a 2.0L NA. The 1.4 of course will have better FC.
My take was on say 2.0L NA and you turbo charged it, then turbo got worse FC. Two different thing altogether.....
Is all in capacity. small engine turbo charged becomes big capacity also. Bigger capacity bigger appetite...@ maybe they came out wit mid boost for optimum power minimum effort
Not to worry Malaysian fuel is "cheaper" than other regional countryIs all in capacity. small engine turbo charged becomes big capacity also. Bigger capacity bigger appetite...
Brunei still cheaper woh!.....Not to worry Malaysian fuel is "cheaper" than other regional country
