Airtrek Project Ongoing
Salmaan
1,503
Kisumu, Kenya
Hi all, I am writing from Kenya, used to be a member on Airtreker, pity that site was discontinued alot of information there. Anyways am currently rebuilding my Airtrek, full engine rebuild, some details below:
Fully forged engine (crank, rods, pistons)
274 Degree Cams.
Nitrided Valves.
Methanol Injection.
3" Internal Diameter Exhaust Front to back with 4.5" tail pipe.
custom intercooler piping.
Link G4 Xtreme ECU with 7 Bar Map Sensor and Bosch Inlet Air Temp Sensor.
and quite abit more
At the moment am wiring in the new ECU almost done.
will post some pics when done with the body work. Project has taken 18 months +.
Salmaan
AvanT
Custom fabricator & CNC machining
360
113
274 Degree Cams.
Nitrided Valves.
Methanol Injection.
and quite abit more
Salmaan
Welcome to our new Airtreker site Salmaan :)
I see another monster in the making, started with the internals 1st huh..
Salmaan
1,503
Kisumu, Kenya
Hi AvanT,
Well it has been a difficult project, started off with turbo, melted a piston, then rebuilt the first time, then spun a rod bearing, so after that am at my current situation, just do everything properly basically install the new internals. I am still using the tiptronic so not going all out as i need to keep the gearbox running. Unfortunately we cant get half cuts for evo's here and even if we do its ridiculously priced so will need to import that.
but long term alot can be done, so lets see how this comes out.
thirdeyes
88
11
508
sabah
after using all this upgrade .. your Oem GB only can stand 300Whp . if you upgrade it still 400Whp . do you think it can hold ?
Has anyone have any experience using 2-way radios? Can they work between 2 people in the same building but on different floors, or between 2 people in separate buildings but the buildings are next to each other?
I know there are many factors that affect connection but I want to know how reliable these 2-way radios are. Or are they good only in open fields?
Thanks.
