Im planning to upgrade my OEM extractor to aftermarket Jasma Approved extractor. im using A/T then should the 4-1 type can makes more power for my engine...:hmmmm:or must be back for 4-2-1 type...
Does your pick up more faster than stock extractor.just wanna confuse u..
i'm using 4-2-1-2 exhaust
mine is all stock standard exhaust systemDoes your pick up more faster than stock extractor.
yours Auto trans or Manual gears...ok la.4-1 i using almost 5 years,not complain at all.20v need going to high rev wat,if not just stick with stock engine .
Aftermarket 4-1 extractor will enhance the high end performance but lose out at the low end.im nearly for RS-R 4-1 equal lenght extractor for my 20V BT auto tranny...its working well or not for street used & sometimes will kick it off...Thanks for advised...
thanks for your advised...Aftermarket 4-1 extractor will enhance the high end performance but lose out at the low end.
For A/T engine to be "fast", immediate response is very important. It mean, low end torque is priority. So obviously, if you use 4-1 in your auto tranny, your won't get an immediate response as what 4-2-1 give to you. You will have to WAIT for the rev going up to hit the power band of 4-1 to get the excitement.
Therefore, 4-1 overall performance in A/T is actually... very turtle
