Advice engine oil for campro engine
abu_busyra
Sep 27, 2010
Hi all
want to ask for the engine oil of my wife's persona (or any other campro engine car perhaps). is it best with full@semi. as of today, I've only tried to use semi as per suggest by the workshop, but now thinking of using full synthetic for next 20k service. is it ok with it? since some of the service center claimed that proton car with campro engine not suitable for full, may resulted some problem in long term. :hmmmm:
thanks.
xtremeleo
3,247
464
id suggest a cheaper mineral, and change every 7000km. elf/total is my all time fave sir
abu_busyra
ic. thanx bos.
hmm BTW, is it really true that full syn oil will bring long term effect to the engine later? or they just saying this to make us 'visit' them more frequent with the 5k oil change..
pangyau
1,153
302
1,683
Malaysia
All type engine oil are good.
It's all depends on your requirement & car specification. Above all is budget.
For new car I second DanzEterna recommendation.
I've been using MOTUL Turbolight 10W-40 for my Waja 1.6 (standard) for almost 7 years.
Service interval depend on usage... but not more then 3 month.
I choose it because the price are in between the Fully - Semi (compare the some other product).
DanzEterna
15,911
3,371
www.primeperdanaclub.com
bro, how much u buy motul turbolight 10w40 4L?
pangyau
1,153
302
1,683
Malaysia
DanzEterna,
Motul Turbolight 10W-40(4L) cost me RM165.00 (the latest price for Borneo)
abu_busyra
owh ok...thanks for all reply guys.
then i kena con by the SC already la ni. I'll go for full syn.
bro pangyau, were u service your engine in 3 month interval even using full syn oil?
imhotep
21
1,503
try eneos 10w/40 semi syn = +-RM 90
or else
eneos 5w/50 fully syn = +-RM145
superb..i tried myself and now stick to 5w/50...really2 smooth
pangyau
1,153
302
1,683
Malaysia
abu_busyra,
They not conned you... maybe they think for your budget.
It depends, I service my ride base on the usage.
Normally around 5-6K km. If the car "xbanyak jalan" then I change around 90 days.
Every morning check your engine oil before start.
Look at the colour & the smell...
If it super dark & smell like burning ash... then need to change la.
If you driving high-rev all the time (5-6K RPM)... the life span will be shorten.
Each engine oil have different characteristic.
This engine oil are Semi Sync... but good for my usage.
simongs
37
6
seremban
my persona se first i was using semi...now using fully syn shell ultra..i felt tht the engine smoother & a little more economical than b4..i dont think will hv adverse effect if use full syn for long term....
abu_busyra
abu_busyra,
were you using full synth when you're saying this? thanks for advice on the engine oil check ya.
---------- Post added at 09:35 AM ---------- 6 hour anti-bump limit - Previous post was at 09:28 AM ----------
then you change the engine oil on what duration time? btw, mind to share which SC u done your service? :driver:
thanks
pangyau
1,153
302
1,683
Malaysia
abu_busyra,
My Waja just 4G18 SOHC 1.6 using Semi-Synthetic oil (as per quoted above)
My friend, Waja Campro also using MOTUL Fully Synthetic 5W-40 (no problem for almost 2 years).
U may use the Fully Synthetic as well (other brand if you like).
Most type (Fully/Semi) of oil good for the engine (Campro) as long you used for daily drive &
not going to burst until 5K-6K RPM all the time.
simongs
37
6
seremban
thanks
with fully syn i change oil filter at 5000km & engine oil at 10,000km duration..previously with semi i change around 6-7000km...im at sban initially i went to the rahang proton edar sc..few times..then nowadays i buy oil & change at a outside w/shop or even myself if got time...thanksss
thor03
Dec 5, 2010
49
508
new car should not having a problem to used fully syn, besides it's the best also compare semi syn......
u see this:
semi syn rm 90 = 5000km
fully syn rm200 = 10000km ...... plus , smooth driving, easy to start and more additive to protect ur engine
now i used fully syn, before this i used Q8 advanced rm180 and now torqo rm 240.... if i be u i just put Q8 advance enough, car smooth n performance also good.....
Local Models
Blue price: height adjustable kit (hi-lo), spring rates of your choice, for ultimate tunablity, be it street sport or all out racing.
Red price: fixed spring seat, using your stock springs, for the ultimate in comfort. An Original Equipment compatible replacement.
(usually for Family...
