Cannot, 3 cartons in boot full already.....Means u shud add 2 more inflated spare tyres in the boot.
My fully adjustable all the while pretty stiff ride. Today ferry 5 cartons of lube to my mechanic, the car damn stable and nice ride......hahahahahahaha
After finish using, refill all with water then keep in boot. Like that feel more stable with adjustablesCannot, 3 cartons in boot full already.....
Aiyah! like that might as well ferry some nice chicks at the back....After finish using, refill all with water then keep in boot. Like that feel more stable with adjustables
Later your wife find some undies on your adjustables how? They left it there as souvenirAiyah! like that might as well ferry some nice chicks at the back....
1. Any sports absorber will have a fast rebound and since it's short stroke, don't expect any sort of comfort. Probably will be softer than your hi/lo but still hard. And paired with normal springs will probably shorten the lifespan of the absorber.Hi Izso and all Guru,
Thanks for your advise again.
The Antiroll Bar i'm using is 18mm and is the biggest.
Need your help to give me some of your opinion again.
I'm thinking about a few combination
1. Stock spring with sport absorber like GAB, tien and so on, will i get less jumpy and handling will improve and at the same time the comfort still remain in a reasonable manner?
2. Sport spring with normal gas absorber, will this also improve the handling and at the same time comfort will not sacrifice too much?
3. Base on what i have on the adjustable SSR300, if i adjust it higher and will the bumpy sensation be minimize to a reasonable comfort rate and handling also still as expected?
Please advise on my above idea.
Thanks.
You can adjust the spring height to improve comfort or handling. ! A 10mm lift will give you better comfort, less bumpy. Try it.Hi Izso and all Guru,
Thanks.
To me, any mod to your original suspension sure bound to be more bumpy.Hi Izso and all Guru,
Thanks.
Mine was the other way around....:hmmmm:You can adjust the spring height to improve comfort or handling. ! A 10mm lift will give you better comfort, less bumpy. Try it.
I lifted mine 20mm and it ran over rough uneven road like nothing, very comfort. But hard driving/cornering suffered, wife complained about boat effects. So I dropped back.
Buy a used welding machine and DIY!Got complain, that is why they use the Tiggo and Hyundai more.
But with 4 of us in the VR the ride not too bad......hahahahha
Actually the muffler exhaust also loud mah! But anyway, saw my mechanic yesterday, told him I am sending in on Monday. The problem is actually the exhaust manifold bolt has broken off. Probably need to take the head out to machine.....
Sachs is a little on the stiffer side, paired with the ultralow APM performax, you're expecting what exactly? Can you spell b-u-m-p-y?So bro if i were to install APM springs, but using SACHS absorbers, anything I need to take note on the setting?
YAlor. Mr Marks having warehouse tool sale. Can rent out your TIG too later. To people like me.Buy a used welding machine and DIY!
i want to sit between the nice chicks..hahahah..Aiyah! like that might as well ferry some nice chicks at the back....
Serious? Hope gf wont complain LOL! Ya is stiff actually. 1 of the reason handling not bad LOL!Sachs is a little on the stiffer side, paired with the ultralow APM performax, you're expecting what exactly? Can you spell b-u-m-p-y?
We will make sure to send the photo to your home minister.i want to sit between the nice chicks..hahahah..
Then what absorbers can be use to match the APM Springs? I know shorter stroke ones but any to recommend?Sachs is long stroke if not mistaken. Long stroke + short springs = shorter lifespan lor.
