no money invest on tyres hehe so just use low profile bridgestone MY-01 nia sob sob
car so powderful use MY-01?..tires sure spin like hell leh..
haha no spin wor coz car not powderful enough to have wheel spin hehecar so powderful use MY-01?..tires sure spin like hell leh..
hi bro,
the thread here seems more active, therefore wanna tumpang tanya...
i had decided to get GSR for my waja, however manual half cut is RM2k more than auto halfcut. My question is whether waja manual can replace for GSR tritonic gearbox or not? if ok, waja gearbox (4G18) can withstand how many horse power or torque? is there any big different compared to waja manual with GSR manual??
thanks brooooooooooo
he's refering to the gb.is there any big different compared to waja manual with GSR manual?? >>> are u refering to the hp?..waja manual got only around 110hp or slightly lesser, the gsr got 190bhp..80bhp more..wat u think?..
4g18 uses 2wd gb n 8" flywheel n clutch engagement by cable. 4g93t uses 4 ws gb with 9" flywheel with hydraulic engagement clutch.hi bro,
1-RAce bearing...? SOmething good to invest on...Hi
Sorry to hijack the thread since I find this thread is the most informative... I want to ask few things but lead to 1 purpose too.. :D
1. How can I get >300whp on 4G93T-RS, any recommendation?
Currently my engine still stock, but the following list of equipments that I have purchased but not yet install
1. K1 forged conrod and 82 bore piston Wiseco
2. HKS GT2835R
3. HKS wastegate
4. Tial BOV
5. COpper Head Gasket .048"
6. 880cc fuel injector
7. Haltech 1000
8. Fidanza Clutch
Next on the shopping list:-
1. ACL bearing, (should I go for stock or .25 for Main and Rod Bearing?)
2. E3 intake
3. E3 TB
4. Lightweight Flywheel (Can CE9A flywheel use on mine?)
Thank you.
Oh yeah.mojoloon:
1: if u plan to use the ACL Racing Series bearing then u have only but one choice "standard size". The ACL Aluglide series might have oversize. my advice open up the engine and see the condition of the crankshaft then decide.
2: E3 intake? can't be used on 4G93 heads. so out of the question.
3: E3 throttle body? Yes. Great investment but u need to bore your intake mani as well to really maximize the flow going in the combustion.
4: Lightweight flywheel is not really necessary if you are going for 300+ whp. stick to standard and go for 3 puck exedy clutch or trinti for that matter. E3 flywheel u need to mod to make it fit out cranckshaft. don't bother with this setup no gain whatsoever.
Hi speed2horizon,he's refering to the gb.
Difference also on the ratio n durability and upgradability when u wants more power with multiplate clutch assembly and also aftermarket or oem LSD for evo gb.
mojoloon:
Err... It's just an automatic gearbox... Triptronic is just a gear limiting fucntion. Nothing fancy. Just like our stock auto GB where we can limit it by having D, OD off, 2, L.. Both using torque converter.Hi speed2horizon,
u mean if i using 4g18, i will need to use back the original flywheel and clutchset? :( because now the clutch is not even able to hold my BOT power....
do you have any experience or heard about tritonic drawback? i afraid i will get alot of problem when i get triptonic. I wont desire for big power at the moment. as long as tritonic can withstand with the existing power..... thx sifuuuuuuuuuuu
