Johnny_Tan
From Facebook
Hi all sifu.. Anyone lettting go old saga 1.5 Manual gearbox?? coz mine sudah "kong".. HELP!!!... :wavey:
Only can help you with the timing belt part, as i just changed mine last year, Gates, with installation rm200..Done by my mechanic. Got a good price for the timing belt though.. rm150.. And according to him, it is original..Oh well..will have it change once it has reached 70K mark..To all 4g91 sifu,
I have a 1997 wira and my year of 4g91 MT transplant is around 2003. Ever since till now, I have never went through a major service or changing timing belt. But so far my engine still running fine and smooth. I forgotten the mileage number when I do the transplant. Currently, my car FC with full tank can go up to 420KM, not sure this is consider high or low FC. In addition, I have quite a heavy wheel with a 60/65 inch profile front and back on a 15 inch rim.
My question is, if I need to do a major service, not overhaul, what are the things I need to change and check ? Also what are the rough cost estimate for each checklist ?
1. Starting what I know for sure is my timing belt. Saw in this same forum which is around RM410 include installation
2. ???
3. ???
Can any sifu shed me some light.
My current dashboard had changed to a CK dashboard, not the original 4g91 dash. Currently, my digital air cond temperature is not working. And I confirm is not the digital panel or its circuit problem, is something to do with the internal parts that comes with the blowers. Does anyone know where i can find a experience wiring guy who experts in this area ?
Bro Elmo_X,sifus
want ask : currently im driving iswara 1.5 carby , planning to get a carby version of 4g91 or is it better to get injection verison
if i go for carby version of 4g91
can i just get the engine only ?? and the rest use back 4g15 parts possible??
or have to do half cut change all to 4g91 parts ??
just buy a complete injection set, why need to buy 4g91 injection halfcut?complete injection set plus labor will cost about 1.5k...but will there be any issue on JPJ ?? since the engine mounting need to have some minor alteration
full 4g91 injection then need get half cut leh , since my ride is carby need totally rip off the whole thing and redo
or are there any cheaper way to change to 4g91 ??
owh sorry man, i thought u already ran a 4g91 carburetor...hmm, if u r thinking of upgrading to 4g91, its better to get the 4g91 injection as the 4g91 carburetor power is not much of a different compares to 4g15...hi bro syimirmazlan
can explain further ??i mean what is complete injection set??
engine only ? remainder use back 4g15 auto??
hello bro...where do u get the idea that 4g91 head wont fit or will lower down the compression drastically?i saw some of ur post stating that 4g91 head jacket is not same bla bla bla...u will make people confuse...I wouldn't recommend 4G93 head on a 4G91 block... u end u lowering your compression drastically... as though 4G91 doesn't already have a low enough compression. =p
You'd actually lose power. =p
Reboring your block to 81mm and use mivec high comp piston or 92 Dohc will help a lot on compensating the 4g93 head. Ive done it. A great rojak recipe!hello bro...where do u get the idea that 4g91 head wont fit or will lower down the compression drastically?i saw some of ur post stating that 4g91 head jacket is not same bla bla bla...u will make people confuse...
4g91 and 4g93 head shares the same water jacket position, and fitting 4g91 wont lower down ur compression...never...
but it wont make as a little good power like 4g93 head simply just because the of the air inlet in 4g93 is a bit better...that's all..
Hi there,hi all forummers here...just wanna ask what is the standard injectors for 4g91..and what is the suitable size for upgrades such as full exhaust setup and high cam?
The terms alien abduction or abduction phenomenon describe "subjectively real memories of being taken secretly against one’s will by apparently nonhuman entities and subjected to complex physical and psychological procedures."[1] People claiming to have been abducted are usually called "abductees" or "experiencers." Typical claims involve being subjected to a forced medical examination that emphasizes their reproductive system.[2] Abductees sometimes claim to have been warned...
