4g13 piston.... maximum oversize
You shave too much off the head, cam timing will change unless you have adjustable cam to counter back....
Before i skim my 4G13 head, i saw below the side got marking i think is the skim limit that your can go. That marking is about 1 mm, and i just skim is flat. Up until now my car does not face any overheat issues, even i rev to 6000 rpm and drive up to 180 km speed. Refer attach picture.
Mine was skimmed to the marking max also :biggrin:
waltertan
Mar 2, 2011
13
503
Selangor
You can still adjust with your timing belt tensioner.
---------- Post added at 07:40 AM ---------- 6 hour anti-bump limit - Previous post was at 07:38 AM ----------
In that case, i leave my spar head original for my future turbo setup. As you have skim to max like my already overheat and warped the head.
Here is my 4G12 low compression ratio piston install my my 4G13 photo for sharing.
looks like low comp turbo piston design...easy to BOT later :driver:
waltertan
Mar 2, 2011
13
503
Selangor
Well I still feel not difference before and after skim.
---------- Post added at 06:24 PM ---------- 6 hour anti-bump limit - Previous post was at 06:23 PM ----------
As for the extra head still have not decide to keep it for turbo setup or not
The Red Bull Rookies team is finally complete following the selection of the remaining two drivers from Singapore and Brunei to join the current two Malaysian drivers that will compete in the upcoming Sepang 1000KM race in December.
Malaysians Mark Darwin, 21, and Siti Shahkirah Shaharul, 17, will be joined by Singaporean Emmiline Ang and Bruneian Fauziah binti Haji Haziz @ Ogy. Emmiline, 23, is the first...
