4g13 piston.... maximum oversize
You shave too much off the head, cam timing will change unless you have adjustable cam to counter back....
Before i skim my 4G13 head, i saw below the side got marking i think is the skim limit that your can go. That marking is about 1 mm, and i just skim is flat. Up until now my car does not face any overheat issues, even i rev to 6000 rpm and drive up to 180 km speed. Refer attach picture.
Mine was skimmed to the marking max also :biggrin:
waltertan
Mar 2, 2011
13
2
503
Selangor
You can still adjust with your timing belt tensioner.
---------- Post added at 07:40 AM ---------- 6 hour anti-bump limit - Previous post was at 07:38 AM ----------
In that case, i leave my spar head original for my future turbo setup. As you have skim to max like my already overheat and warped the head.
Here is my 4G12 low compression ratio piston install my my 4G13 photo for sharing.
looks like low comp turbo piston design...easy to BOT later :driver:
waltertan
Mar 2, 2011
13
2
503
Selangor
Well I still feel not difference before and after skim.
---------- Post added at 06:24 PM ---------- 6 hour anti-bump limit - Previous post was at 06:23 PM ----------
As for the extra head still have not decide to keep it for turbo setup or not
hye guys, im new here..hehe
just want to get some info bout the defrent between crossmember and subframe. because if want to transplant a myvi engine to kelisa engine bay will required to use storia or yrv subframe\crossmember rite?....den wats the defrent between kelisa and yrv\storia subframe\crossmember....very appreciated if could giv a details bout this....thanks...hehe
