4G13 cam
synail
hi guys
im planning to get myself a 270 in 275 ex camshaft
and adj cam pulley for my 4g13 motor
Am i gonna have trouble idling with the a/c switched on?
im no sifus.. but using 270 degree above sure will affect the idling.. normally they uses ficd to increase the idling level for aircond.. discuss with ur mechanic first..
Cam too high, difficult to drive too. 1.3L cannot extract much from that power plant....:smokin:
hi guys
270 in 275 ex, that's a pretty mild cam la. The a/c might be affected a little but otherwise you'll be fine la.
Thanks all....really appreciate it
Can i really feel the performance gain after installing
this kind of cam?
If it is mild cam, don't expect too much from it, right?
this kind of cam?
You'll feel a difference for only a certain range, depending on how you set the cam angle. Whether it's significant or not depends on your car.
Spend so much don't get the significant difference then want to cry already.....:bawling:
But when oversize piston and snail is a big bunch of money flying off at once. :stupid:
No need, buy the Satris turbo I mentioned if available.......hhahahhahahah:rofl:
But you get smaller car.....:rolleyes:
