The Pulsar in the video is SR20DE....not SR16VE.
Eventhough AE111 has the smallest engine in 1.6 category don't underestimate its potential.
Mated with 6MT even better....
Copied from Wiki..I couldn't agree more..plus stock ignition timing..very conservative and safe ignition timing..no contest if stock 4agze wanna fight b16, 20v and Neo..my own opinion la..
---------- Post added at 11:13 AM ---------- 6 hour anti-bump limit - Previous post was at 11:10 AM ----------
we compare stock to stock der...hehehe..b16b stock no 1.8 block one..
AUTECH TUNE is more towards bodykit..just a few minor touch up on engine.The Pulsar in the video is SR20DE....not SR16VE.
What is B16A "small" VTEC and what is B16A "big" VTEC bro...Just to add, B16A (non Type R) has two types... "small" VTEC and "big" VTEC.
Thx VTEC taikor.[/COLOR]DeaconFrost,
generally,small Vtec refers 2 d 1st gen of B16A...normally found in DA Integras or EF Civics/CRXs...pushes out abt 160ps(manual transmission) compared w d latter version of B16A(generally known as Big Vtec) whc is used in d EGs, & EKs,170ps.......
D7zul,
aiyaa..of coz B16B uses d same block as a b18CR but as ur findings thru wiki,it's still a 1.6L,right?as per thread topic,all comparo is btween 1.6 stock NA engines mah?masuk d supercharged engine,of coz i say no fair lar....ahhahaha.......heck,u can even plonk in a B20 crank into d B16B block...all same height.....so,unless u r talking abt attempt 2 curi ayam,of coz d B16B has alot of "jalan" ler,hehehehe
n aikss??stock Neo VVL uses 86mm pistons 1 ar?wahlau....i heard it's 85mm n dat's oredy BIG enuff for 1.6L.....it's actually running on 86mm?no wonder d torque damn monstrous!
---------- Post added at 12:27 AM ---------- 6 hour anti-bump limit - Previous post was at 12:25 AM ----------
DeaconFrost,
B16A got two types, 160ps and 170ps. 160ps (locally known as small vtec) came from Civic EF9, CRX EF8 and Integra DA6/DA8 early model. 170ps (locally known as big vtec) came from DA6/DA8 later model, EG6/EG9, Del Sol EG2, EK4.Dude civic got so high? On paper I never seen it advertised so high... Always 165 hp only... Where this info from? Some B16A again... Not B16B..
Gear ratio absolutely plays a big part.IMHO however high the cam spec is...gear ratios will always play an important part in delivering the best out of the cams. and the driver's skill also...hihihihihi
