Jun eK9 tak payah ajar hattech-v dia pura pura sahaja. try to pretend like he dunno anything like that he also among the top vtecs...:regular_smile:
thats rite jun... sharing is the best thing here...Jun_EK9 said:nvm laa....if he know also im happy....just dont keep it to ourself only
whats the advantage using smaller aluminium pulley? is it bcoz of the material or bcoz of the size?Jun_EK9 said:undersize alu pulley will do a great job
poji_EG9 said:Yazer...trust me...b16a conrod (top side) cannot fit with PCT piston...mean cannot plug n play just like that...need to cut a 1mm left & 1mm right...type r b16b conrod (top side) is smaller than b16a conrod....but piston pin diameter still same....better use b16b piston pin which come together with PCT piston itself.
We cannot cut 0.5mm left & right due to not enough clearance....
so need 1mm left & right....will cost u rm60~80.
PCT b16b piston price= rm540~560 (4 unit)
Ori B16b piston rings 81mm = rm440 (4 sets)
but u can use brand NPR or RIK at rm120~130...
or u can use back yr OEM b16a piston rings if still ok.
Labour cost rm400~800.
J101 said:ace79
think you need to watch the dvd again with a big popcorn. it was a p30 piston actually. all i can say they were trying to overkill a 14yr old engine and see what can be done if its been done(fittings, lubing, torquing,installation) correctly. dont forget the expensive clutch, hondata and extractors. they were pushing 9xxx rpm at an high altitude dyno machine. thats another hell of a stress test.
