Reliability is an issue when you go overboard with big pistons.
Again from what i gather, TX3 83mm pistons on B16A/B16B/B18C/B18C5 block (2mm overbore), liners will crack after continuos hard driving at high revs 9k+rpm. Mainly due to too much frictional force during high rpm on the very thin wall liner after 2mm overbore. But many ran 81.5mm and 82mm forged piston with no problem on liner.
I have personally seen 86mm K20A pistons on B20B block (again 2mm overbore) where after 2 session of 15 lap half track SIC MSS race rpm limiting to 8300rpm only, and on the last cooling lap the engine die. Back to workshop, the moment they remove the head, block liner just broke right through!!
So from what i see, to be a reliability motor, you cannot overbored 2mm and should only restrict to 1mm bore. That is why if you see those forge piston manufacturer in USa, the moment the size is overbore more than 1mm it will state sleeving needed.
Just saw 2 weeks ago at my mech place, where he assembling a customer B20B block which has iron sleeved and bored out to 87mm piston!! I believe they are H22A pistons. And should see how thin the sleeved bore between the pistons. Damn thin... I wonder how they can bore further for 88mm?? hmm...
