yup...if u've extra budget better get b16b enjin kosong....all spec/dimension u can get from it...b16b engine as we know have much more stronger n lighter internal.....b16b enjin kosong have oil cooler at oil filter adaptor, block girdle at the bottom of crank shaft, semi race camshaft, longger/lighter conrod, lighter valves with good dimension for air flow, different dimension of valve seat, dual spring for exhaust, haha this long block have advantage which can rojak with b18cr internal later on for future upgrading....and many more.
but not all people know, actually b16a block+b16a head+PCT piston will produced more higher compression ratio than ori b16b (CTR).
- rojak b16a block + PCT piston + b16a head = 11.1 :1 CR
- can produced torque 15.2~15.4 kg-m.
- ori b16b (CTR) = 10.8 : 1 CR
- usually standard torque around 14.6~15 kg-m.
