its a good reference then.. thanx for posting it up
about the cable things.. care to explain more why u said it will not lead to stable voltage with less resistant cable? because my knowledge on this electrical things quite low (almost to none heheheh) but still if u only said because the dyno run doesn't show increment in h.p it seem like it can be debate the validity of the result unless U mention it being run on engine dyno with inside control environment room...or u run a test in the test rig with high speed camera to see the different of the spark for different type of cable...hope u can explain in engineering ways....or post a quick link regarding the analysis of it...
the main question shud be dis sir, are the oem plugs really dat bad compared to the aftermarket dat it produces substantial amount of interference to render the output voltage unstable? at least i dont think so..
as for the test, weve tested and already got the results, conclusion was done based on dat test. the test was done in the real world scenario, i dont think there is anything better, do you? u rnt the only who studies in a uni here sir, ive done tests / experiments in labs / workshops, and found out they can only be used as a reference and most cant be applied in real life, because too many assumptions are made to perform the tests, whats ur opinion on dat subject matter sir?
not all here are engineers, i dont wanna make things difficult by explaining in too many technical terms. i can use the jargons we use in electrical / electronics engineering, but iam not here to explain to u alone, i hope u understand sir. iam explaining / citing my own experiences, i dont have any link for dat..
i think we shud be moving on to another useless mods, anyone? i remember sumone posted about fancy plugs?
