Weird Sound from Left Suspension
dvino
92
10
1,508
hi Guys,
Need some help here:itsme:.
After 9 years I went out for a date last night
The chick was complaining that the car is to noisy but she liked it :love:( thansk to timmy :)
I was driving on a curvy road and I took a very narrow and hard right corner.
Well there is good news and a bad news about that almost 80 degree right corner:
Good news : She hold my hand because she was exited or freaked out..who cares my objective is achieved
Bad news: some kind of noisy appear on my left suspension side. It like water splashing or plastic had straggled to the arm. I also found that there is significant amount of water on my passenger side carpet.:mad:
( I went for a car wash the day before)
Well I freaked out after that and I was driving completely slower on the corners and the sound is not that noisy... it then disappeared on straight line.
Any idea guys what this could be:stupid:?
bohtak
32
check your aircond drain pipe, it must have been stuck or moved in an angle, hence water leak tru the passenger carpet. the water splashing sound is because the water that is trapped at the drain pipe area is hitting your exhaust manifold when its hot, creating that splashing noise you hear.
Vagabond
1,731
53
1,648
yup ...... i pretty much had the same experience as well.
except that sometimes ...... my car carpet wet ..... is not because of water!!!! :thefinger:
dvino
92
10
1,508
thanks guys will check that this weekend :)
timmy, get a room la :burnout: kesian your car
The Marketplace Top Posts
I drive a Daihatsu G100 Aura.
Here's the problem:
My engine idling without the air con is 1000. That's fine with me. But when I turn on the air con, it shoots up to 1300!
Can anyone suggest a solution?
Thanks in advance
