5th gear weird problem
Shoken7
193
some advice or recommendation to fix this weird phenomenon ?
i can engage 1-4th gear with no problem
but when it comes to the 5th gear , after engaging the gear for a few seconds,
the gear will pop out by itself and goes to neutral
if i hold it down with my hand on the 5th gear, it can go on w/o problem
everytime i let go the gear knob on 5th gear , it goes back to neutral
what could have caused this problem?
---------- Post added at 04:10 AM ---------- 6 hour anti-bump limit - Previous post was at 01:53 AM ----------
i've done some reading and research
possible reasons i've read are
1.) gear box fluid is low
2.) Shift cable is corroded at the transmission
(replace cable bushing if corroded or replace the
transmission case housing, 1-2 shift fork, 2nd gear set,
1st gear, and 5th gear.)
does that mean my whole gear box has to be replaced?
3.) syncros worn out?
Shoken7
193
ic....thanks..
i remember some mech quoted me rm500-700 few years ago for a syncro
is that a right price? or kena potong? :S
gilos
141
yup no.3 is the answer
happened at my proton just recently(mileage >200k), replaced the parts n it cost me around rm300 :) . Hope can last another 200k...hahaha
honda may be a bit expensive...i dunno.
E-Tech
1,115
256
3,183
Johor
If new about that range....
If got mech friends good condition 2nd hand should do the job also and less $$$
But to bring down gearbox also labor charge of Rm1xx...
Wanggot
3,906
62
Jay Bee
Happened to my Satria once... Replaced only 5th gear itself bro.. Dunno abt Hondas
Shoken7
193
lol
thanks gilo for confirmation
i sure hope its not as expensive as i remembered
Shoken7
193
@ E-tech
then the money i prepare should be sufficient for 2nd hand part with labour
hopefully..lol..still havent got the time to go to any workshop yet..deng
---------- Post added at 01:59 PM ---------- 6 hour anti-bump limit - Previous post was at 01:58 PM ----------
@ wanggot
replace whole 5th gear? how much did u spent for your satria?
Wanggot
3,906
62
Jay Bee
@ E-tech
@ wanggot
RM2++ inclusive gear fluid, labour and 5th gear taken from chopshop
Guys,
help needed to ask about the topic above.. i bought a half-cut and nowadays, all halfcut comes in the airbag must be exploded or be cut.. therefore i need to redo the steering wheel coz mine has a tip-tronic function..
is there any where around KL or PJ or Subang doing this? how much does it cost?
