Guys,
Need some advice. Whenever i start my car in the morning and put it onto "D4" to drive, the first gear change to second gear is ok but the change from 2nd to 3rd gear is a bit problematic/weird. The thing is the rpm would rev up to around 2500 and suddenly my car will feel like loosing power. It tends to try and die at around 2500 rpm and even i i floor the pedal the rpm doesnt go up. Not until a second or two then it resumes back to normal rpm speed and the gear changes are normal.
It is the same case if i park my car for more than an hour and when i put it into D4 the same thing happens again. It is only from 2nd to 3rd gear change.
By d way, im driving a 96 civic auto transmission. Please help guys as i am afraid this small problem might cause to a bigger problem later on.
Thank you.
G.
Thank you.
G.
