balancer shaft removal
jinkl
4,624
376
3,183
its a normal practice to reduce load to ur engine
they remove this so that the balancer belt can be eliminated
the old way was alwiz
chopping the shaft and making a stub out of it
which would look like this
but the newer practice is to machine up the current shaft to remove all the weight and still maintain the shaft ends , like pic below
there has been some theory and ppls review that the first way gave some issues relating to the oil pump and bearings.
RB4840
1,508
yes mr jinkl i prefer the new method the first way tend to give problem lah maybe experienced ppl can explain this
jinkl
4,624
376
3,183
by AMS, even GSC practices the same way
Eliminating the balance shaft not only frees up horsepower, it also reduces the chance of belt failures ending up in catastrophic damage to your motor. In our experience, replacing the front balance shaft with a stub shaft will increase the chances of oil pump failures. This is likely caused by eliminating the support provided by the rear bearing journal. A stub shaft allows the oil pump gears to push apart and wear into the aluminum pump. Aluminum that is being worn away will enter the clean oil stream and contaminate the engine bearings. Eventually this can result in the oil pump seizing. The AMS shaft is machined to eliminate the counterweight while leaving the bearing journal in place to keep the factory engineered support for the oil pump gears.
RB4840
1,508
thank jinkl for your useful information i totally agree with u, i have seen the wear of the aluminum parts that u mentioned. tq
bebolagalas T
733
29
this oil pump issue is a turbo killer Journal Bearing esspecially... No matter we use Ori turbo or China turbo..if oil pump fail..ur turbo and engine in big trouble..i vote for the AMS balancer shaft..
AlucarD
1,079
115
5,163
Personally, I do not think that this is a worthwhile mod unless you're doing all out time attack, racing or drag race and that every Hp or seconds counts...........
The work, time and money involved for a few HP gains?
jinkl
4,624
376
3,183
thanks for the intake manifold , looks good :P
got poison my fren or not ? i heard te06 24v popped out
bebolagalas T
733
29
yes bro..last piece hehe..very good price..with 16cm2 turbine t3:bawling:
---------- Post added at 04:14 PM ---------- 6 hour anti-bump limit - Previous post was at 04:10 PM ----------
well said...alwayzz think twice or trice for every mod before do it..:hmmmm:
goo_61t
660
12
nice piece
whts the price like for one of those , vr4
just take out ur ori balance shaft and sent them to machine shop laa cost lest then purchasing new so called race balance shaft. Actually they also machine it from the OEM unit.
spuzzle
741
9
Kuantan / Perth
thx for all feedbacks!! created this thread because i need to overhaul my engine due to worn conrod bearing...so might do it together
A unusual Ford Focus we have here today. It is in a brand new condition barely a week old.
From the looks...
