Need some Help , Advise and Suggestion
ckwanloong
160
11
on the other hand...let's say if our tps and o2s faulty twice a year...then the amount can buy a k-pro without suffering the o2s issue...even more benefits frm k-pro such as speed cut...anti lag ...v-tec point and bla bla bla...~this is what i'm thinking now,but not sure whether it's better!! what do u think?
Vagabond
1,731
53
1,648
with K-Pro , you can run open-loop system at all times , so the faulty O2 sensor wont become an issue.
CKwanloong : TPS ....ummm ..... 3 or 4 times.
MAP sensor : changed once only.
prasath_5338
1,131
19
Bro, TPS and o2 sensors is a must.... kpro is not a substitute....And there is no way your sensors kong every year.....:biggrin:
ckwanloong
160
11
juz now kenal again.....switch on air-cond then the engine died....couldn't start .....!! haiz...damn hate this~~but i plug a obd2 diagnosis ,it showed only o2s ..no map sensor...no tps...so i'm juz so confuse with tht...should i replace map sensor?? and i think even o2s sensor kong wouldn't cost enginse mati then cannot start~!!
---------- Post added at 09:19 PM ---------- 6 hour anti-bump limit - Previous post was at 09:08 PM ----------
sorry cause...not cost @@
Vagabond
1,731
53
1,648
anybody know about inverted tie rod end for dc5????
i think tracy sports or m&m honda have those.
J's racing has the whole steering rods set, not just the ends.
some local fellow i spoke to was interested in modyfying stock honda rod ends to be similar to those aftermarket ones, but still just contemplating that idea only.
the main purpose was to ensure correct Toe adjustments for super lowered cars with significant camber.
boulala
461
15
yes... i know someone can custom made it for DC5. anybody interested with inverted tie rod end... maybe a group buy...
i think j's tie rod are not inverted. they are just shorter right.
Vagabond
1,731
53
1,648
yup, you're right. the j's ones have shorter length compared to the stock one.
should do a group buy :biggrin:
i bought a LED scanner but dunno how to fix cause the wiring code dunno .1st i fix in the ingination when turn off engine the scanner will light ups .but i found it not so good . i would like to fix it in the alram system wiring. i mean stock alram when on guard the scanner will lights up. could some1 plz help me with this . thank you . my car model kancil 850 ex model99 .
it would be good if provide step by step guide picture , tutorial and diagram for me begginers to understand...
