dun wori bro!
its ok to use 205/40R17.
those gen2 majority using tis size.
cheers!
Once the plastic panel in the wheel arch rubbed off,the "noise" should also go away...Heheh!
The rim offset is wrong causing the wheels to rub against the balck fender plastic..if possible use 205/45/17 tires or 215/40/17...max width is 7.5 for our Gen2 rims...use R3 springs for money well spent
:wavey: hi guys, im new here. just fitted 215/45/17 to my persona but havent lower it yet. plan to do so. any suggestion whether to change spring or go for adjustable? some people say can use Eibach Pro Kit, cost around RM800 and use with OEM suspension. any pro and cons?
Bump: :wavey: hi guys, im new here. just fitted 215/45/17 to my persona but havent lower it yet. plan to do so. any suggestion whether to change spring or go for adjustable? some people say can use Eibach Pro Kit, cost around RM800 and use with OEM suspension. any pro and cons?
205/40 with 7.5 should be ok..all depends on yr rims offset..Gen2 oem is +42 if i'm not mistaken...
have try 205/R16/50, 205/R16/45, 205/R17/40 & 215/R17/45. For me, the best for look and perf, is 205/R16/45 (currently used). Last time, used 205/R17/40, look superb and pick up not bad (still can spin tyre in 2nd gear) but bad for suspension parts (bengkok both camber screw..... hehehe)
215/R17/45---> so lembab like kura2 (plus sangkut at rear)
No can do to ketuk2 at rear as, it'll touch the rear bumper (saw one that cut all the bumper, ok la, but dangerous to tires)
change ur spacer lah........try out.ada pakai tak????
Similar threads | |
