DIY Smoke Headlamp for kelisa
crazeeclan
shah alam
Those red circle are the screw attaching the bumper to the body...total u got 9 screw...after remove the bumper screw...remove those green screw...those are the headlight screw...each headlight got 3 screw...all are size 10 screw...u need a long head size 10 screw...canot use normal spanar coz the screw behind signal lamp and behind number plate there very narrow so normal spanar cant fit in...
This is after i seperated the light...sorry no pic when process of removing...but what i do is...i use hair dryer to blow at the gap between rear n front pcs of the light...then use a flat head screw driver and slowly separate it...pour abit of boiling hot water at the silicon to soften it then faster separate the light...took me 1 hour plus just to separate 2 headlight...
After separate it...tape and cover the reflector...remember to check and see any left out...it not u wil accidentally spray your light reflector....
Spray the reflector with RM5 FLAT BLACK color...no need to sand paper the reflector...just wipe it with clean cloth to make sure no dust or dirt.
Same goes to this...no need sand paper it...just wipe it with clean cloth...and make sure it really dry before u spray...after the paint is dry up..apply another layer on it...i apply 3 layer overall...
After spray..remove all those tape and pump abit of transparent silicon (RM8.90 bought at hardware shop)at the "longkang" then attach back the rear n front pcs of the headlight..and this is the result of it....
Spray = RM 5
Silicon Sealant = RM8.90
100 Plus = RM 3.90
Marlboro Light = RM 9 but smoke few stick only
Result of the headlight = PRICELESS SATISFACTION :D
wah,so clever arr...just curious if water can penetrate inside...:confused:
actually any headlamps, sure abit of moisture will go in.. thats why behind every headlamp, there's like a small hole (normally connected with an 'L' shape rubber tube pointing downwards) to allow moisture to go out once you switch it on and heats up the temperature inside..
just make sure no BIG drops of water to pass through, then you'll be fine.. just seal back the place you open properly..
wow good job bro as i know most ppl scared to open their headlamps cuz takut water masuk headache but ur daring respect!:wavey:
Just to share =)
This is how mine turned out, started with matte black then sprayed on with Gerhana Grey, result's almost like gunmetal in my opinion =)
put headlight into oven for about 3-4 mins, it's faster & easier to seperate the cover....just dont overcook it!....
put back again in again after you're done and applied back the silicone sealant, then take out and press it while it cools.
Good as new....
haha...DIY is about trial n error...so have to take the risk...till now...i have help to DIY 5 pair of headlamp for kelisa ady...and the best part is there is no anyone complain water get into inside of the headlamp...:biggrin:
Bump:
Good as new....
use oven abit risky...i only use hair dryer and hot water...very fast...
Yoh.. Bro Crazeeclan,
Need ur help..May i know wat brand and where u bougth the Silicon Sealant??
I think i bought the wrong silicon sealant..:bawling:
thank you
thank you
bought the silicon from hardware shop....u just tell the shop fella transparent silicon for plastic...bought at RM8.90 per tube only....tube like those colgate tube...
