![](http://img378.imageshack.us/img378/7900/dsc00111me7.jpg)
Those red circle are the screw attaching the bumper to the body...total u got 9 screw...after remove the bumper screw...remove those green screw...those are the headlight screw...each headlight got 3 screw...all are size 10 screw...u need a long head size 10 screw...canot use normal spanar coz the screw behind signal lamp and behind number plate there very narrow so normal spanar cant fit in...
![](http://img378.imageshack.us/img378/4525/dsc00114tj1.jpg)
This is after i seperated the light...sorry no pic when process of removing...but what i do is...i use hair dryer to blow at the gap between rear n front pcs of the light...then use a flat head screw driver and slowly separate it...pour abit of boiling hot water at the silicon to soften it then faster separate the light...took me 1 hour plus just to separate 2 headlight...
![](http://img385.imageshack.us/img385/7993/dsc00115nb5.jpg)
After separate it...tape and cover the reflector...remember to check and see any left out...it not u wil accidentally spray your light reflector....
![](http://img152.imageshack.us/img152/4844/dsc00116yr3.jpg)
Spray the reflector with RM5 FLAT BLACK color...no need to sand paper the reflector...just wipe it with clean cloth to make sure no dust or dirt.
![](http://img155.imageshack.us/img155/5804/dsc00118kj1.jpg)
Same goes to this...no need sand paper it...just wipe it with clean cloth...and make sure it really dry before u spray...after the paint is dry up..apply another layer on it...i apply 3 layer overall...
![](http://img254.imageshack.us/img254/2601/dsc00121fe0.jpg)
After spray..remove all those tape and pump abit of transparent silicon (RM8.90 bought at hardware shop)at the "longkang" then attach back the rear n front pcs of the headlight..and this is the result of it....
Spray = RM 5
Silicon Sealant = RM8.90
100 Plus = RM 3.90
Marlboro Light = RM 9 but smoke few stick only
Result of the headlight = PRICELESS SATISFACTION :D
